anvil (Jun 25, 2001 12:07 p.m.):
qc notes that he has idle of 30 C and a load temperature of 50 C in another post elsewhere.
I would say that until he get the load temp down to sub 40's, he isn't going anywhere.
qc, reapply the thermal compound (not paste, ... but the kind you get at Radio Shack or a brand name like Artic Silver) and make sure you have good thermal contact with the cpu. If that doesn't bring it down, then I think you might just need a better cooling system or a better processor.
anvil
qc (Jun 27, 2001 08:50 a.m.):
10x Allan, I'll tray to lap my orb.
This paper thin layer of thermal grease must be all over the bottom of the orb or in circular area only?
Is noname thermal grease will help?
e_storm (Jun 28, 2001 07:53 a.m.):
*edit*...as a test, try taking your side covers off the case and blow a house fan on the cpu and see what your load temps are then. If you don't see an big improvement, I'll hang up my OCing hat...j/k.
Pinky (Jun 28, 2001 10:08 a.m.):
Don't say that, I tried this and it didn't work on my system, needed a case fan and case mod in order to more efficiently make the heat exchange...
hate to see you leave!
e_storm (Jun 28, 2001 12:14 p.m.):
[What does everyone else think?
I'd normally think this wouldn't make a big difference either (depending on case fan setup), but the reason I suggested it to him was because he told me his case temps under load were 39* C and cpu was 50* C, with an ambient in the mid 20s. Thats a case temp of 14*C above ambient. I think by getting some good airflow over the board, it should reduce temps. What does everyone else think?
