New attack has 100% success in SSDT hook
Ageeb
St. Paul, MN
Researchers say they've devised a way to bypass protections built in to dozens of the most popular desktop anti-virus products, including those offered by McAfee, Trend Micro, AVG, and BitDefender.
The method, developed by software security researchers at matousec.com, works by exploiting the driver hooks the anti-virus programs bury deep inside the Windows operating system. In essence, it works by sending them a sample of benign code that passes their security checks and then, before it's executed, swaps it out with a malicious payload.
The exploit has to be timed just right so the benign code isn't switched too soon or too late. But for systems running on multicore processors, matousec's "argument-switch" attack is fairly reliable because one thread is often unable to keep track of other simultaneously running threads. As a result, the vast majority of malware protection offered for Windows PCs can be tricked into allowing malicious code that under normal conditions would be blocked.
All that's required is that the AV software use SSDT, or System Service Descriptor Table, hooks to modify parts of the OS kernel.
"We have performed tests with [most of] today's Windows desktop security products," the researchers wrote. "The results can be summarized in one sentence: If a product uses SSDT hooks or other kind of kernel mode hooks on similar level to implement security features it is vulnerable. In other words, 100% of the tested products were found vulnerable."
The researchers listed 34 products that they said were susceptible to the attack, but the list was limited by the amount of time they had for testing. "Otherwise, the list would be endless," they said.
The technique works even when Windows is running under an account with limited privileges.
Still, the exploit has its limitations. It requires a large amount of code to be loaded onto the targeted machine, making it impractical for shellcode-based attacks or attacks that rely on speed and stealth. It can also be carried out only when an attacker already has the ability to run a binary on the targeted PC.
Still, the technique might be combined with an exploit of another piece of software, say, a vulnerable version of Adobe Reader or Oracle's Java Virtual Machine to install malware without arousing the suspicion of the any AV software the victim was using.
"Realistic scenario: someone uses McAfee or another affected product to secure their desktops," H D Moore, CSO and Chief Architect of the Metasploit project, told The Register in an instant message. "A malware developer abuses this race condition to bypass the system call hooks, allowing the malware to install itself and remove McAfee. In that case, all of the 'protection' offered by the product is basically moot."
A user without administrative rights could also use the attack to kill an installed and running AV, even though only admin accounts should be able to do this, Charlie Miller, principal security analyst at Independent Security Evaluators, said.
The Register
Research source
this person took the info it seems from a report that came out 7 years ago with the same explination, but is now trying to sell the fix, [H] noted that, seems like plagiarism someone said and someone trying to scare people with old info.
Since when does an AV scan code, and then ignore all code after it?
good points. I guess my view was why does a vulnerability that was discovered in '96, still succeed with todays av's...
the way I understood it was the attack bait-and-switches After the security check, but before execution, use (or however you'd phrase it).
This book came out 10 years ago and it talks about rootkits that work around HIPS. Not to mention all sorts of reports that came out a few years after that, which talked about service hooking.
Personally, I have seen stuff like this from Matousec before. "Independent researcher" my ***.
