- Sep 29, 2011
Hey everyone, new to the forum, and wanted to get some input on the temp for my new build.
This is the new build I put together to replace my long out-dated gaming rig, in preperation for the upcoming season of games, including Battlefield 3, Skyrim, etc...
So far, I'm extremely happy with the performance, everything at stock speeds (aside from the pre-overclocked video cards), and have been able to run everything I've tried at max settings 1080p.
In the future I will most likely be overclocking it, but not until I get a better cooling solution for my CPU and case, when I need to OC.
As of now, I wanted to get some input on my temperatues, and if they were acceptable/good, or if I should be addressing a problem with my system the way it is.
To test my temps, I ran Battlefield Bad Company 2, at full settings, at 1080p, for a about 30 minutes.
After about 15 minutes the temps started to top out, and remained for the rest of the test.
My CPU at load was 63c
My GPU (1) was at 66c, and GPU (2) was at 55c, with both fans at about 75%.
Ambient temp in the case was 35c.
At Idle:
CPU is ~45c
GPU1 is ~ 48c
GPU2 is ~35c
Ambient is ~31c
Are these temps decent for stock cooling, and safe to run for the future until I want to overclock?
System Specs:
Core i5-2500k (Stock)
2x MSI 560 Ti Twin Frozr II in SLi
16GB DDR31600 (G.Skill Enthusiast Series)
Asus P8P67 Deluxe Mobo
Corsair 850W TX Enthusiast Series PSU
Coolermaster NV 690 II Advanced Nvidia Case
At Idle:
CPU is ~45c
GPU1 is ~ 48c
GPU2 is ~35c
Ambient is ~31c
System Specs:
