Hello as some of you already know I decided to upgrade my computer. I already got the parts and put them together. I currently have two problems right now. My DVI-D port doesn't work on my brand new graphics card. I checked it with two monitors (doesn't work for both). However the DVI-I port works perfectly on both monitors. My monitors are pretty crap quality, one is an acer monitor 1600x900 @ 60Hz refresh, and the second one is as old as... I don't even know. Can this be the problem in the faulty card? The both monitors are VGA and I use two adapters. One DVI-I and one DVI-D adaptor. (I also have two DVI-D adaptors, neither work).
My second problem is that the bios doesn't detect my RAM speed corrently. My RAM speed is 1866MHz, and that what is says on both the sticks and the both. In bios it only displays it as 1600MHz. However I can overclock it to even 2400Mhz I belivie. So why is that? Should i overclock it manually? But isn't it weird is not automatically it's formal speed?
My specs:
CPU
Intel Core i7 4790K @ 4.00GHz
RAM
8.00GB Dual-Channel DDR3 @ 1866MHz
Motherboard
ASRock Z97 Extreme6
GPU
GTX 970 (Msi)
My specs:
CPU
RAM
Motherboard
ASRock Z97 Extreme6
GPU
GTX 970 (Msi)
