That's interesting! Okay, so I went and downloaded several items from Asrocks website before I saw your reply. (Intel INF, Intel RST, Intel Lan drivers) Would you recommend me reinstalling the OS and not downloading these 'extra' drivers? Basically since i'm starting fresh I wouldn't mind reinstalling.
Second question, and I am puzzled about this:
My Mobo, the z370 TaiChi, has 3 m.2 slots, and depending on which one you use the SATA ports will be disabled. I get that. However, in the manual it states " To minimize the boot times, use Intel Z370 SATA ports SATA3_0) for your bootable device"
Well, since i'm using the m.2 as my bootable device, which m.2 slot should I use? Does it matter? Should I use the m.2 slot which would then disable the SATA3_0 port?
Does this make sense? From the motherboard guide (see below) it appears since I have a m.2 pcie, and use the M2_3 slot, I'll still have all my sata ports available for use? But if that's the case, will having the m.2 in M2_3 be slower than M2_1?
- - - Updated - - -
Here is from the manual. I just don't know which m.2 I should use for maximum performance.
Serial ATA3 Connectors
(SATA3_0_1:
see p.8, No. 13)
(SATA3_2_3:
see p.8, No. 14)
(SATA3_4_5:
see p.8, No. 15)
(SATA3_A1_A2:
see p.8, No. 16)
These eight SATA3
connectors support SATA
data cables for internal
storage devices with up to
6.0 Gb/s data transfer rate.
* M2_1, SATA3_0 and
SATA3_1 share lanes. If
either one of them is in
use, the others will be
disabled.
* M2_2, SATA3_4 and
SATA3_5 share lanes. If
disabled.
* If M2_3 is occupied by
a SATA-type M.2 device,
SATA3_3 will be disabled.
time, use Intel® Z370 SATA
ports (SATA3_0) for your
bootable devices.
The M.2, also known as the Next Generation Form Factor (NGFF), is a small size and
versatile card edge connector that aims to replace mPCIe and mSATA. The Ultra M.2
Socket (M2_3) supports SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3
x4 (32 Gb/s).
* If M2_3 is occupied by a SATA-type M.2 device, SATA3_3 will be disabled.
