...I wonder if the 390X BIOS would offer any benefit for the 8GB 290X...
The 'ungodly reason' was my way of saying, there isn't a difference between the cards, period. No efficiency increases. It is what it is last I understood.There have been some people flashing their 290x with a 390x for some ungodly reason (same EXACT card sans 8GB vRAM). But outside of that, I haven't run across any.
Yes, they did. Outside of some microcode and bios changes (which makes GPUz tell you what kind of card it is), its the same thing as the 290x 8GB with faster clocks.They didn't just slap a 3 on it.
Since all R9 300 Series cards are rebrands of existing R9 200 Series products, we don't expect any significant power consumption improvements with the R9 390X; these will hopefully come with the Fiji GPU on the Radeon Fury.
The Radeon R9 390X is based on the "Hawaii" silicon (now referred to as "Grenada" without any silicon changes)
The MSI R9 390X Gaming we are reviewing today is based on a re-brand of the R9 290X. The clock speeds have been increased a little bit, but the GPU itself is the same, offering the same features, such as shader count, ROPs, and texture units. Only memory size has been doubled to 8 GB, a capacity that has been available on some R9 290X cards before.
My recommendation, especially when on a budget, is to look for a R9 290X with 4 GB because it can be had for around $300. Overclock it some and boom, you have R9 390X 8 GB performance levels at a fraction of the price.
, while the rest of the lineup saw a cascading re-badging from the previous generation. AMD's previous generation flagship, the HD 7900 series, went on to become the performance-segment R9 280 series, and so on, and the performance-segment "Tonga" silicon was added afterward.The story is predictable even today.
With this generation, there is essentially one new silicon, the HBM-equipped "Fiji," which will be launched later this month and will eventually drive up to five products from AMD. The previous-generation flagship silicon "Hawaii" now drives AMD's performance-segment products, the Radeon R9 390 and R9 390X we're reviewing today.
The Radeon R9 390X is based on the "Hawaii" silicon (now referred to as "Grenada" without any silicon changes) and features the same core-configuration as the R9 290X.
...The Radeon R9 390X delivered exactly what you'd expect for a slightly beefed up R9 290X with 20% faster GDDR5 memory.
Power consumption figures were comparable to previous generation cards, with the R9 390X being in line with the R9 290X for example.
The power consumption difference of 3w isn't remotely compelling. I can get 10 reference cards and show 10w difference between them or one card a few watts just on different fan speeds.. I would expect it to be about the same or more considering the ram. It could just be binned slightly better as ram doesn't use much power anyway (a few watts).
To confirm, as i stated earlier here, we would need to match clocks and drivers. The summary shows a 10% difference over all their games tested...which can easily be clockspeed and driver differences...or just clocks.
http://www.techpowerup.com/mobile/reviews/MSI/R9_390X_Gaming/30.html
From tech spot (you should read the intro to that article too):
So again, it is tbe same exact die. Same shader count, rops, tmus. If there are any differences it came through the microcode and the bios... but I haven't seen anything compelling otherwise. Outside of the fury, fury x, and nano, these are rebrands with more memory and different clocks. Outside of that, they are the same thing.
Richard Huddy said:There are changes to the silicon
Pcper said:So what changes were made in these new spins of GPUs? AMD was quick to comment on the term "rebrand" that will no doubt be associated by many with the Radeon R9 300-series. They insist that engineers have been working on these GPU re-spins for over year and simply calling them "rebrands" takes away from the work the teams did. These GPUs (the 390 and 390X at least) have a "ground up" redesign of the software microcontroller that handles the clocks and gating to improve GPU power efficiency. As you would expect for a GPU built on the same 28nm process technology that has been around for many years, AMD has tweaked the design somewhat to better take advantage of evolutions in TSMC's 28nm process. And, thanks to higher clocks on both the GPU and the memory, performance increases will be seen over the existing R9 200-series as well. Being able to run around 50 MHz higher on the GPU and 250 MHz (1.0 GHz effective) on the memory inside the same power envelope shows that AMD has done SOMETHING, though how much that means for consumers is up in the air.
pcper said:UPDATE: I used a modified version of the Catalyst 15.15 driver to re-test the Radeon R9 290 and saw nothing that points to AMD purposefully altering performance with the driver swap.
