New Cooler: CRYORIG R1 news release
doyll
Disabled
UK
New company CRYORIG has a sweet looking cooler coming soon.
News release
We are proud to Introduce to you CRYORIG
CRYORIG LLC, announces the arrival of the R1,
CRYORIG’s first flagship CPU cooler.
Officially founded in 2013, CRYORIG is a fresh new comer to the PC peripherals and Cooling market but with a core team of seasoned veterans. Our team’s resume include experiences with renowned brands such Thermalright, Prolimatech and Phanteks. With our experience and drive for innovation and improvement we are proud to present our very first flagship dual tower solution, the CRYORIG R1.
The R1 is an accumulation of years of research and design. Putting good use to our multiple manufacturing and design patents, the CRYORIG R1 is jam packed with multiple one of a kind features. The long list of features include our patented DirectCompress™ full contact soldering process, Jet Fin Acceleration System™, Heatpipe Convex-Align™ and Displacement Optimization™ Systems.
The R1 will be featured in two flavors, the R1 Universal and the R1 Ultimate. The R1 Ultimate will have two XF140’s full 140x26mm fans, and the ability to add a third XF140. The Universal version features one XF140 and a thin profile 140x13mm XT140 silent performance fan, offering terrific performance with almost no tradeoff for performance and compatibility.
The CRYORIG R1 Ultimate, XF140 and XT140 are set for release on January of 2014 and the R1 Universal is set at February 2014 for select countries.
Please visit www.CRYORIG.com for the latest product information and release dates.
Website has more pics and details.
Finally got price & pics of R1 Ultimate with black shrouds! :clap:
CRYORIG R1 Ultimate - MSRP of $89.95
A Closer look at the CRYORIG R1 Ultimate
CRYORIG’s first launch product the CRYORIG R1 Ultimate is the accumulation of years of research and design. CRYOIG is now revealing a more detailed explanation and closer look at the R1 Ultimate’s extremely long list of trademarked technology and patented designs.
DirectCompress™ Soldering
CRYORIG’s patented DirectCompress™ Soldering, increases the actual contact surface between the heatpipe and heatsink fins. Traditional soldering requires a cut out area next to the heatpipe through hole in order to pass through soldering tools. DirectCompress™ Soldering requires no cut out and has on average at least 10% more contact surface compared to traditional soldering, and the more contact surface the faster the heat conduction.
Heatpipe Displacement Optimization™
On aluminum sheets, heat spreads out in a radial direction. By displacing the heatpipe alignment on the heatsink fins, our Heatsink Displacement Optimization™ allows for better and more evenly spread heat conduction on the fins compared to traditional linear alignment.
The individual tower stack on the R1 Ultimate is separated into two sections, the wider gap air intake and the high density exhaust section. By the laws of fluid dynamics, the increase in fin count in the exhaust section squeezes airflow and increases exhaust air speed. The increase of airflow speed in our Jet Fin Acceleration System™ allows heated air to leave the tower faster.
Heatpipe Convex-Align™ System
The R1 Ultimate’s Heatpipe Convex-Align™ System allows for more heatpipes in a given area, optimized heatpipe placement in the copper base, and improved alignment with your CPU. With the Heatpipe Convex-Align™ System, each heatpipe functions to their maximum TDP capacity.
Acoustic Optimizations
Acoustics are just as important as performance. That’s why both the XF140 and XT140 140mm fan integrate acoustic optimizations. Both fans featuring High Precision Low Noise (HPLN™) Sleeve Bearing and the detachable Acoustic Vibration Absorbers that gives the fan a snugger fit while canceling vibration and noise at the same time.
Patent Pending “MultiSeg™” Quick Mount System
CRYORIG’s MultiSeg™ Quick Mount System, features a 1.5mm thick mechanical structure reinforced metal backplate and precision pressure calculated spring screw mounting system. The MultiSeg™ Quick Mount System delivers a quick, ultra secure and sturdy all in one solution on Intel LGA115X platforms. Mount your R1 Ultimate in a matter of minutes.
Product Warranty
Besides the trademarks over trademarks of features, the R1 Ultimate is offering up to six years warranty upon product registration. Each CRYORIG product (besides the CP9 Cryo-Paste) will come with a unique VIP Product Registration Card. By registering your product you not only extend your product warranty to the max of six years, you also instantly become a CRYORIG.com VIP member. VIP members are instantly eligible for our worldwide VIP prize draws, and get a chance to win limited edition products and more!
Product Specifications
CRYORIG R1
Dimension ( with fan ) L130 mm x W140 mm x H168.3 mm
Weight ( with fan ) 1248 g
Weight ( without fan ) 936 g
Heat pipes 6mm heatpipe x 7 units
Copper Base C1100 Pure copper nickel plated
XF140
Dimension L140 mm x W140 mm x H25.4 mm
Weight 156 g
Rated Speed 700 ~ 1300 RPM ±10 %
Noise Level 19 ~ 23 dBA
Air Flow 76 CFM
Connector 4Pin PWM
The CRYORIG R1 Ultimate is scheduled for release on Jan. 2014, in select countries and regions. North America, Japan and Korea MSRP is set at 89.95USD. Please stay tuned to CRYORIG.com for further launch information and regional pricing.
For detailed explanation of the R1 Ultimate please visit:
http://www.cryorig.com/r1-ultimate.php
For full high-definition product photos of the CRYORIG R1 Ultimate, please visit:
http://www.cryorig.com/p_gallery_lists.php
Had an early Christmas present! CRYORIG R1 Ultimate showed up late yesterday so decided to post a few pics. Very good first impression!
Side view without fans and shrouds.
Closeup of base from side
Not as deep as 14PE
Everything you could need is included. Even extra fan clips and rubber corner mounts.
XF140 fan and included accessories
More later.
Merry Christmas!
You have to post some results and compare it to your Phanteks cooler and see which comes out the winner!!
Merry Christmas,
AJ.
Indeed! :thup:
Will be running it against TC14PE and Silver Arrow SB-E. I have TY-147 and TY-143 fans to test against the XF140 fans and PH-F140HP.
Probably have to overclock my 920 to get enough heat.. may need some help with that. ;)
Started setting up to test and found a surprise in bottom of fan accessory box.
Red and white vibration absorbers!
Sorry for the delay.
Just getting over the flu.
Have mounted R1 and am running some heat cycles to make sure it's seated good. Have to admit I'm liking what I'm seeing so far. :D
Same here i am really suffering with this Flu, will wait to see what you have in store for us.
AJ.
Finally better and caught up with everything that had to wait on the flu.
CryOrig have now released the R1 coolers and fans in Japan, Korea and Taiwan. Today I've seen two German retailers having them priced €69.90.
Have most of the testing done now. I have absolutely no complaints. The CryOrig mount is a pleasure to install, R1 Ultimate is beautiful and performs great. I'm not ready to say it's the best but it is definitely right up there.
I'm now building my Define R2 with the R1 Ultimate to use for a bit and take some photos.. LOL... My photo "skills" and "studio" are a joke, but will have some pics up hopefully tomorrow.
Than I'll be back on the test station for more testing of PH-TC14PE and Silver Arrow SB-E for comparison to R1 Ultimate. As soon as I start running these test I will be able to say just how good I think the R1 Ultimate really is.. but until than I don't actually have confirmed comparisons.
Reason is my original testing was done with a GA-EX58-UD3R under i7 920 and that changed to a GA-X58A-UD3R. Rest of components are the same... my gut feeling is test results if not identical will be very close to what they were before.. probably less than +/-2c.. and as much as I would like to have tighter tolerances, with all variables in play I believe it's realistic. Results are probably only +/-1c, but to be safe I'm saying +/-2c.
Comparison of R1 Ultimate to others show:
Silver Arrow SB-E Extreme 2.6c cooler,
Silverstone HE01 is only 0.5c cooler,
Dark Rock Pro 2 is 4.1c warmer,
NH-D14 SE2011 is 7.9c warmer.
Another Cryorig R1 Ultimate review is out!
It shows XSPC Raystorm 750 EX280 is 4.6c cooler than Cryorig R1 Ultimate. Interesting how a cooler (H2O) costing almost 3 times as much and is only 4.6c cooler. ;)
