- Aug 12, 2002
- Chicago, IL
GOAL is to crunch as much BOINC as possible, and this seems to lead to the conclusion to get the most / cheapest PCIE slots possible.
A company near me is selling some of their older computers, winxp, 160gig drive, 3 gig ram, BUT, they are Ausus A8N-SLI with athalon 64x2 processors.
Key is, the A8N-SLI has TWO Pcie slots .....
They're asking for $250, but I think I can get a couple at $200. The powersupplys are 550 watt, unkown details.
I'm trying to figure out if it would be cheaper $$$ per rac to drop some cuda cards in these, or build a new system.
PRELIM CONCLUSION - given the numbers below, even though I'd rather get sexy new hardware, it looks like the older used systems are cheaper per PCIE slot.
QUESTIONS
1) I'm mostly discounting the processor differences, since it seems CUDA dwarfs the processors in performance. Should I be counting the CPU differences?
2) Should I look at the intel systems? Quick glance looked like multiple PCIE was cheaper on the amd boards.
3) What else should I look at? Should I bump down the specs in the new systems to get a better comparision?
SCENARIOS BELOW
Assume the same PCIE cards to be used in all systems.
OPTION A $700
get THREE of the a8nSLI systems = 6 PCIE slots, three amd64 dual cores
OPTION B = 4pcie slots, $780, and it doesn't look like this would produce much more rac than option A
NEW SYSTEM GUESSes
MB 4 pcie $170
amdx4 3ghz $140
case $60
RAM $230ish
power supply $180
OPTION C GO BIG OR GO HOME $1000, 6 pcie
Gigabyte 6 slot PCIE $250
Amdx6 $200
CASE $120 (big chasis)
ram $230
power supply $200
OPTION D
Sell 6 Geforce 260 cards ( /shrug, $125 each?) buy 6 new geforce 460 cards ($200 each?) total cost $450. ANYONE GOT A GUESS as to how much more rac I'd get with 460s over 260s?
QUESTIONS
SCENARIOS BELOW
OPTION A $700
NEW SYSTEM GUESSes
MB 4 pcie $170
amdx4 3ghz $140
case $60
RAM $230ish
power supply $180
Amdx6 $200
ram $230
power supply $200
OPTION D
