- Jan 22, 2003
smokenjoe said:That is one of the most complete real world wright ups that I have seen.
It tests the DDC against DD4 the Eheim 1046 and 1048 The DDC come out on top except for a slight loss of flow to the DD4. They tested in a high restritive and low restritive system and measured sound on a foam pad. The most interesting this is that it was as quiet if not more quiet than the Eheims and pumped far more! They had a sound clip if you are interested. It was far quieter than the DD4. I only wish they compaired it to an Eheim 1050 which should have done better than the 1046 and 48. The charts are easy to read if nothing else. I did not understand the heat output calks but it appears from the callks that heat generated should be much less than the DD4. This article has me reexamining my decison to get a Eheim 1050.
Its not too surprising the DDC performs so well. Im sure Apple gave Liang very strict requirements. Hence why the pump will cost that much. But hey I'd use one in a blink of an eye for a small setup
