- Mar 6, 2002
- Connecticut
Hey all,
We're moving across the country to a new place and after researching cable TV options to accompany my 42" HDTV, I've decided that for the $140/month that it'd cost me to get digital TV with HD channels and a DVR, I'd instead try an HTPC only using media available on the Internet or physical media (mostly Netflix & HULU). Also, I will be piping audio out to an AVR.
With that in mind, do you see any glaring holes in my build or any suggestions to bring cost down a bit? I do know that my case choice might be scrutinized, so my justification was this: Small form factor = happy wife, front panel card reader, integrated IR receiver, solid construction.
I've done a lot of research to zone in the best power consumption - noise - performance - function - price ratio ... however any advice is welcomed.
Thanks for taking a look.
- CASE - Moneual MonCaso 312B - $240.00
- MOBO - Gigabyte GA-H55M-UD2H - $87.00
- CPU - i3 530 Clarkdale - $115.00
- PSU - Antec EarthWatts 430w - $50.00
- RAM - Crucial 2gb (2x1gb) DDR3 1333 - $58.00
- HD - Samsung Spinpoint F3 1TB - $70.00
- BLUERAY - LITE-ON 4x Blue-Ray Reader - $65.00
- WIRELESS - TRENDnet 638APB Access Point - $55.00
