- Jan 20, 2002
RJA this install is only about a month old. If i do a nuke it will be to go back to win 7.
Ive had java problems. My VLC media player keeps crashing. I hate that even tho i have disabled the login screen in both the GP and Reg it is still there every time i boot. now this problem......im running 64bit win10 with 64bit programs
In my experience, while a restore will often remove the symptoms it can leave any installed infection(s) in a dormant state, residing somewhere, waiting again for the right conditions to re-activate itself. Sorry if I sound pessimistic, but just wanted to give you a heads-up based upon my personal observations when cleaning systems.cozumel i have had one problem after another since i have moved to win10. I like the look and some of the newer features but i dont like the stability.
i did a system restore and i think i have fixed it but this is not the first time i have had to do a system restore since i have had win10 on my system. my last install of win7 lasted me well over 2 years without a single system restore. just not happy with it.
I don't know if you are on a Win10 upgrade, but if so, then maybe a totally clean install could help you with the multitude of problems.cozumel i have ran all of those in the order that you told me to and have found 0 threats. so going with that im guesssing win10 doesnt like me.
