Djspinister
- Sep 3, 2013
RIG SPECS:
1200w PC P&C Modular Platinum
EVGA X79 Dark Mobo
i7 3930k CPU
4 x 500GB Raptors
2 x Samsung 840 Pro 256GB SSD's
2 x 3 TB WD Red NAS drives
1 x ASUS BR Burner
1 x Corsair 32GB 4x8GB Memory Kit
1 x MSI 7970 Lightning Graphics card
Ok so now that you know all that here goes. After defective CPU's, memory issues and the like I have ended up here and am very frustrated. I had Windows 7 Ultimate already installed at one point on a single SSD. The end result is suppose to be Raptors in RAID 5 and each SSD by itself, as well as the 3 TB drives. Again after I installed windows, updated everything, installed all the main programs, even getting to this point took the better part of two days getting things replaced over a holiday weekend.
I tried setting up the RAID 5 on the Marvell controller with no success. It would only do 0-1-10. So I moved the Raptors to the Intell controller and set it up no problem, although that messed up my Windows install, at the time I didn't have a problem with it because to be honest the install was super fast and the RAID was more important. Got the Raid setup and then tried to install Windows 7. I have two ways of doing so, either my Patriot Flash Drive or I have an actual Windows 7 Home Premium Disk.
1st if I load the disk it loads Windows like it should but it goes straight to the "Load Driver" screen and wants me to insert a disk. No matter what drivers I install it still does not see any drive!! No SSD, no Raptors, no NAS drives, I have tried each one, one by one and on different controllers all by themselves.
2nd if I try to load it from my USB drive it goes straight to Windows Boot Manager screen, tells me it cant read from the config data.
Important to note, I have two of everything except the drives, meaning Mobo, CPU, Memory, and I have changed each one out one by one and it is the exact same!
Any ideas? Thanks either way in advance!
EVGA X79 Dark Mobo
i7 3930k CPU
4 x 500GB Raptors
1 x ASUS BR Burner
