invictius
Disabled
- Oct 8, 2005
Just want some advice of which of the following components I'd like have the best price-to-performance (value for money) ratio. Touch wood, I'll never need a system for a long time, but I'd like to see how cheap things have gotten in the last 5 years.
I currently have:
p4 3ghz
geforce 6800 (has vga out, which is important, also has svideo out, which is VERY important)
4x512mb ddr400 ram (you know, ddr1)
motherboard with spdif-in! (having this is very important)
some generic but good tv capture card
sound blaster audigy - no idea if its a 1 or 2, but it has coax out. Can't believe that in almost a decade, they STILL make you buy an add-on board for spdif! (looked at some new sound cards and can't find ANY with spdif in)
antec sonata case (hate this, since you need brackets, but it's thick steel, which I imagine is good for cooling, as there is no place to put it other than 10ft from a heater)
raid card (not using it for anything except having a 3rd IDE port, can't believe new boards don't even have 2!)
1x160gb IDE, 1x300gb IDE, 2x750gb SATA
2 IDE burners
380w psu with an AT 250w running some stuff to take the load off the main one
Parts I want (since I would be using some from the old system):
Please note I'm not in the north america region therefore quotes from newegg etc aren't of much use to me, just best brands and stuff thats universally best value for money will do
P4 quad core
Geforce 9-series at least (though I'm not a gamer, these seem amazingly cheap - remember, must have tv-out, would REALLY like component out! Had bad experiences with ATI in the past)
Board that supports ddr-3 ram, with 4 ram slots, would be great if it had the standard 2 ide ports! At least 4 pci slots (no idea if pci-e ones are compatible with pci devices)
At LEAST 4gb ddr-3, would really like 8, but will start off with 4 if price means that I have to
Half-decent brand power supply, guessing it would be at least 550w?
A case that isn't cramped as all hell!
I already have:
hard drives and burners as mentioned before, not really interested in blu-ray as I'll probably get a ps3 soon, but would like a blu-ray burner when they become affordable
sound card (though sadly no spdif-in)
Here's what I've come up with, all prices are AUD and online - I've had a retailer match online prices in the past, but if this can't be done, I'll just shop around until I find one that will:
CPU
Intel Core 2 Quad Q9550 (2.83Ghz/12MB/1333FSB/EMT64/XD/Quad Core) $429.00
MOBO
ASUS P5E3 QuadCore, X38, FSB1333, DDR3, 2xPCIEx16, RAID, GbLAN, 1394a, ATX $249.00
PSU
Antec EarthWatts 650W ATX Power Supply, 80 PLUS certified , 120mm low noise cooling fan, Dual 12V outputs, 2 x PCI-Express, 4 x SATA, 6 x IDE $135.00
CASE
Thermaltake VD6000BNS Black Soprano VX, ATX, 120mm Fan, Front I/O, NO PSU $115.00
VIDEO CARD
Asus EN9800GTHB-HTDI-512 Geforce 9800GT 512MB, DDR3, PCIE2.0, 2xDVI, HDTV, HDCP, HDMI $249.00
RAM (x2)
OCZ OCZ3G13334GK 4GB Kit PC3-10666 2GX2 GOLD XTC C9 $560 (for all 4 2gb modules)
Comes to just a bit under $2k AUD, these parts (apart from the RAM and CPU) are the best value for money/compromise parts I can find.
This is going to be in a fairly warm environment, so if there's any reason I shouldn't go with intel, please do let me know. My p4 3ghz prescott gets to 70 at full load, and this is with correct airflow and a gigantic Zalmain fan. I'd really like something that I can just bring home and not have to fuss about it overheating.
One last thing, will quad-core support XP? Vista needs a lot of stuff ironing out IMO, and a couple of users on here have said it's better to stick with XP anyway, as its had 7 years and 3 service packs to get stable enough.
I currently have:
p4 3ghz
2 IDE burners
P4 quad core
I already have:
CPU
MOBO
PSU
CASE
VIDEO CARD
RAM (x2)
