- May 29, 2005
- Sprinkles!
New to Forum, 1st project visualization, opinions?
Updated 5/30 - Added system sketches as promised, see end of post
- I haven't started the mod yet, once i do and i have pics, i'll move to
the project log section
Greetings All,
First Post!
Following the advice of a friend at work, i've been lurking for about a week.
Whats in the Box (pics linked, links at bottom of post)
Antec SLK-1650B with stock 350w Power Supply
Asus P4P800SE Mobo ( No wireless Module )
Intel Prescott P4 3.0E rev. D0 ( non-OC'd, but OC'd by a friend @ 3.7ish
CoolerMaster Hyper48 cooler with AS5 thermal grease
512mb PC2700 Kingston & 512mb PC2700 Supertalent
Gigabyte GeForce FX5200 Video Card
1x 80gb EIDE Western Digital Master
1x Maxtor EIDE Removable Slave ( loud as heck )
1x 160gb SATA Western Digital
1x Lite-on DVD/CD-RW
Future upgrade plans:
-Replace RAM with 4x OCZ DDR PC-3200 Rev 3 512mb Modules
-MSI GeForce 6600GT 128mb AGP 8x Video Card ( NX6000GT )
-Sound Blaster Audigy2 ZS Platinum Sound Card
-Seasonic s12 600w PS
Mods so far ( mostly store bought stuff, tiny bit of custom )
Added Green UV Side fan with single CCFL UV ring
Swapped out rear 120mm with Green LED lighted fan
Added front LED UV Green 80mm fan
Installed Vantec Nexus 4 channel Fan Controller
Custom ( read: cobbled together mock up) HDD Cooler -> see my post in project logs regarding this mod
Installed some store bought Round EIDE cables ( thick! x.@; )
Modding plans ( i'll be posting a rough sketch of my ideas later on )
-Replace Motherboard tray with clear Acryllic
-Replace 5 Bay HDD Cage with custom lower profile cage
-Cut up front panel from the bottom of the 5 1/2" bays down, replace with custom "louvered" Mesh
-Dremel out inside front of the case for 1x Green Lighted 120mm on bottom ( case ventilation ), and 1x Green lighted 80mm above that ( blowing on HDD's )
-Compartmentalize HDD's to seal off from the rest of the interior & Independantly cool them (air )
-Stealth Optical drive & Hide removeable Maxtor behind spring loaded delete panel
-Replace Vantec Fan controller Chassis with Unused delete plate ( to get rid of crappy lettering ) & change blue LED's to green
-Relocate Fan Controller to top of case inside custom Metal enclosure w/ acryllic door, maybe a couple USB up there too.
-Acryllic windows on both sides ( i haven't seen alot of folks showing off the back of the motherboard too )
-custom rounded EIDE cables, black mesh sleeving
-sleeve all possible cables
-perhaps integrate my IPod dock? haven't decided
-Hinge both side panels & install locking releases, i was initially thinking of using the recessed door handles from a Jeep Wrangler, since they're plain & square
-Modularize the Seasonic s12 600w PS when purchased, encase in UV green acryllic
-install 1x 12" UV CCFL tube, and 1x 12" green CCFL tube, but make them impossible to see the tubes themselves unless the box is upside down
Some bling, but not a ton of it. The goal is a really clean modded box.
The windows on the sides are going to be as large as possible, however i haven't decided what i want to do to them. If anything i'll do some sort of custom etching myself, otherwise they're going to be plain-jane clear.
I want to keep with the overall theme of the lower front of the case, but flatten it out and stretch the louvers to almost the corners to give it an almost utilitarian look from the front. Between the stealthed drives, and louvered mesh, it's going to look interesting.
If you aren't familiar with the case, here's a link: Antec SLK-1650B
Hope my post wasn't TOO long =P thanks to the folks that read this far! I welcome all suggestions & ideas, if you spot a problem with the setup, please let me know!
Front of case next to Server
Whole Case
Case Open
Open case, Full Mobo View
Mod sketches ( planning )
Thanks again!
~ Gos
*insert witty signature here* =)
Greetings All,
First Post!
Whole Case
Case Open
Thanks again!
~ Gos
