Hi guys. I currently have an air cooled Mini ITX build that I am looking to upgrade to the new Ryzen when it comes out. I think I might want to try my first water cooled loop. I plan to step up to a mini ATX, just for the extra room for radiators and pumps ect. I currently have a RTX 2080 that I would like to have in the loop as well as the CPU.
I am hoping to get a few recommendations on what components I should go for since I haven't really purchased anything for the new build yet except for the 2080. I am hoping to start with a case that is good for water cooling. I may need either one large radiator or two smaller ones depending on the layout. I would also like suggestions on the actual water cooling gear. I know EK is popular, but I may want to go for a kit if that is something I should consider. I don't really care too much too much about RGB or even showing off the build, but I would like a case with the most glass/clear plastic just to be able to quickly check on the system at a glance. The Thermaltake Level 20 looks awesome, but seems to get mediocre reviews.
As far as overclocking, I actually don't plan to do any of that, but I do need to be able to push my ultrawide 3440x1440 monitor for gaming at about 100hz. I am not sure if I covered all the info, so please let me know if I left anything out. Thanks!!
