nf7 Barton 2500 won't oc at all-NOW RUNNING AT220X10
hi guys i bought an nf7-s rev 2 and its got a barton unlocked 2500 on it; i've done everything i know to get it to take some oc but it just won't budge, and i figured i'd ask you guys what you think the most likely problem is. the ram is aome cheap kingmax pc3700, right now im running it at 3-2-2-2 and the powersupply is a 500 watt owermax i used for a couple of years now. the 3.3 rail is all good, the 12 rail is juuust a bit weak, the voltage on the processor shows a little bit less than i have the bios set; bios is stock; i hook the cpu voltage up at 1.775 and wind up w about 1.74;
Now thing is, that i cant get this puppy to go past about 172 fsb, no matter what; voltage does'nt give me much, for example if i hook it up at 1.85 it still won't go past about 174 and of course it runs hotter; i cool it w air, and i have a hose from outside so im spraying the **** out of it w 20 degree F air, and it runs at about 39c full load; (im pulling in w a 92mm fan and hosing the silent take with another ducted fan so its gettn washed pretty good with icy air; i got a 92 mm fan washing the northbridge and backside of my 9800 pro, and another 92mm fan washing the FRONT of the vid; also 4omm fans blowing out; its as cold as my ex-wife's lawyer's heart in there;
acpi is off in windowsl the spread sectrum is off for agp and fsb, the mem voltage is 2.9, the agp is 1.6, the cpu is 1.775;
it'll run prime95 blend of course but when i put it on a tough prime95 test it'll error fast; and windows will rush, and glitch, 3d games won't run, if i try to get it past 172;
Would you guys like to speculate for me things i should do differently?
i'd appreciate it, cause SOMEthin ain't happening here, and i'm not sure what to think.
(by the way i have it set now at multiplier of 13.5; whatever the fsb will do, itll do at some good multiplication; but he fsb won't climb, even if i drop the multiplier to say, 9, and try to keep the speeds around stock; as i type its runing at 2300mhz, but of course i'd like to be running a wider pipeline thru fsb speed; )
