I'm having a problem with the keyboard and mouse not working on every other post in the bios on the NF7-S.. Now when I mean post, I mean even the keyboard isn't working useing the delete key to enter the bios.. So I can't get into it (bios) without cycleing the reset switch.. With one push of the reset switch, all is back to normal.. It's not a WinXP problem because it happens even before XP loads. USB ports arn't a factor either.. I'm useing the PS/2 ports for both keyboard and mouse.. About the only thing I haven't tried to do is buy a keyboard and mouse to check the USB to see if it is doing the same thing..
Any suggestion would be great for ideas on this problem...
Swiss®
__________________
Specs:
ABit NF7-S
AMD 2400+ AIUCB 0243
Cosair XMS PC3200
GF3 TI200
2 40GB Maxtors 7200 on SATA (Raid 0) Stripping
1 WD 7200 40GB Primary IDE
SwiftTech 462+ with Vantec 80MM at 5700RPM 92CFM
Swiss®
__________________
Specs:
ABit NF7-S
Cosair XMS PC3200
GF3 TI200
