- May 17, 2005
- High Desert, Calif.
Just got my taxes done, the tax guy just bought an all-in-one HP desktop, including wireless keyboard & mouse. Apparently there is no indicator light on the keyboard, and someone told him he had to purchase software to have some kind of caps-lock notifier display, in Win 8. I find this hard to accept, so I did some googling and came up with the following solutions(?) :
1. change settings solution
url
2. Third party software solution
Download & install CAPSLOCK-Notifier
Would either of the two above approaches be a 'recommended' solution, or is there a better way to invoke a caps-lock indicator, in Windows(8)?
url
go to control panel > Ease of Access > Make the Keyboard Easeier to Use. Check the box next to Turn on Toggle Keys.
EDIT:
I found this answer for Windows 7, it may also work for Windows 8.
- Click Start.
- Type Keyboard in the search field.
- Double click on Keyboard options.
- Under Key Settings tab, go to the Key Settings List.
- Locate and double click on CAPS LOCK
- On the menu where it says Display CAPS LOCK status on screen
- Click the check box, and click Finish
