so if i disable acpi, and apm would be pc turn off regular still?
Yea, basically, unless by some means APM can't be enabled. Your best bet is to disable ACPI in the bios when you reinstall windows. You can install APM after you disable ACPI, but sometimes XP acts weird about that.
