No window mode WTF mate
Speciale
Disabled
woodstock illinois
So i built the computer in my sig and the game i play most frequently does not work. Crazy, since it only needs about half the brute of this computer...whatever
Falcon 4.0 will not load with the XP drivers and the 8800 (it works fine in Vista)
Nvidia has said it isn't a driver issue but there should be a fix in the next driver
Lead Pursuit has said it isn't a game issue but there should be a fix in the next patch
Neither has given me what i want. Whatever, a workaround was found...it should hold me off for a while
Put computer in 16bit mode, launch falcon.exe in window mode...game plays fine, looks like turd, but plays fine.
I had been doing this for a month, yay. Then a few weeks ago i reformatted, now I CAN'T LAUNCH ANYTHING IN WINDOW MODE
Any idears?
Here be dis for all u free flowin mudas
Code:
System Information
Time of this report: 2/23/2007, 22:34:09
       Machine name: DESKTOP
   Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
           Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
       System Model: System Product Name
               BIOS: BIOS Date: 09/06/06 17:43:50 Ver: 08.00.12
          Processor: Intel(R) Core(TM)2 CPU          6600  @ 2.40GHz (2 CPUs)
             Memory: 2048MB RAM
          Page File: 291MB used, 3648MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: NVIDIA GeForce 8800 GTS
     Manufacturer: NVIDIA
        Chip type: GeForce 8800 GTS
         DAC type: Integrated RAMDAC
       Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_C8213842&REV_A2
   Display Memory: 640.0 MB
     Current Mode: 1600 x 1200 (32 bit) (85Hz)
          Monitor: ViewSonic P95f+
  Monitor Max Res: 1600,1200
      Driver Name: nv4_disp.dll
   Driver Version: 6.14.0010.9792 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
 Driver Date/Size: 12/21/2006 11:29:00, 5745536 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp: n/a
              VDD: n/a
         Mini VDD: nv4_mini.sys
    Mini VDD Date: 12/21/2006 11:29:00, 5747488 bytes
Device Identifier: {D7B71E3E-42D3-11CF-B27D-2BE803C2CB35}
        Vendor ID: 0x10DE
        Device ID: 0x0193
        SubSys ID: 0xC8213842
      Revision ID: 0x00A2
      Revision ID: 0x00A2
      Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
 Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result: Not run
 D3D7 Test Result: Not run
 D3D8 Test Result: Not run
 D3D9 Test Result: Not run
Sound Devices
            Description: SB X-Fi Audio [BC00]
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: PCI\VEN_1102&DEV_0005&SUBSYS_00211102&REV_00
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: ctaud2k.sys
         Driver Version: 5.12.0001.1187 (English)
            WHQL Logo'd: Yes
          Date and Size: 8/17/2006 11:17:10, 500480 bytes
            Other Files:
        Driver Provider: Creative
         HW Accel Level: Full
              Cap Flags: 0xF5F
    Min/Max Sample Rate: 1, 192000
Static/Strm HW Mix Bufs: 128, 64
 Static/Strm HW 3D Bufs: 128, 64
              HW Memory: 0
       Voice Management: Yes
 EAX(tm) 2.0 Listen/Src: Yes, Yes
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
               Registry: OK
      Sound Test Result: Not run
Sound Capture Devices
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x41
           Format Flags: 0xFFF
DirectMusic
        DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
     DLS Version: 1.00.0016.0002
    Acceleration: Enabled
           Ports: SB X-Fi DMusic Synth [BC00], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
                  SB X-Fi Audio [BC00], Software (Kernel Mode), Output, DLS, Internal
                  Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  SB X-Fi Synth A [BC00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  SB X-Fi Synth B [BC00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  SB X-Fi MIDI Port [BC00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
                  Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  SB X-Fi MIDI Port [BC00] [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
                  Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
        Registry: OK
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: Natural® Ergonomic Keyboard 4000
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x00DB
        FF Driver: n/a
      Device Name: Logitech Dual Action
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC216
        FF Driver: n/a
      Device Name: Microsoft eHome Infrared Transceiver
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x006D
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2830
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/10/2004 06:00:00, 57600 bytes
| Driver: usbd.sys, 8/10/2004 06:00:00, 4736 bytes
+-+ USB Human Interface Device
| | Matching Device ID: usb\class_03
| | Service: HidUsb
| | OEMData: 03 00 08 10 0C 00 00 00
| | Driver: hidclass.sys, 8/3/2004 23:08:20, 36224 bytes
| | Driver: hidparse.sys, 8/3/2004 23:08:18, 24960 bytes
| | Driver: hid.dll, 8/10/2004 06:00:00, 20992 bytes
| | Driver: hidusb.sys, 8/17/2001 14:02:20, 9600 bytes
| +-+ HID-compliant game controller
| | | Matching Device ID: hid_device_system_game
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/10/2004 06:00:00, 14848 bytes
| Driver: kbdclass.sys, 8/10/2004 06:00:00, 24576 bytes
+ Microsoft eHome Remote Control Keyboard keys
| Vendor/Product ID: 0x0471, 0x0815
| Matching Device ID: hid\vid_0471&pid_0815&col05
| Service: kbdhid
+ Microsoft eHome MCIR Keyboard
| Matching Device ID: hid\vid_0471&pid_0815&col06
| Service: kbdhid
+ Microsoft eHome MCIR 109 Keyboard
| Matching Device ID: hid\vid_0471&pid_0815&col07
| Service: kbdhid
| Driver: kbdjpn.dll, 8/17/2001 22:36:18, 8704 bytes
| Driver: kbd106.dll, 8/17/2001 14:55:56, 6144 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC506
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 8/10/2004 06:00:00, 23040 bytes
| Driver: mouhid.sys, 8/10/2004 06:00:00, 12160 bytes
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 23.7 GB
Total Space: 35.3 GB
File System: NTFS
      Model: WDC WD360GD-00FNA0
      Drive: D:
 Free Space: 248.9 GB
Total Space: 476.9 GB
File System: NTFS
      Model: ST3500630AS
      Drive: E:
 Free Space: 176.6 GB
Total Space: 238.5 GB
File System: NTFS
      Model: ST3250824AS
      Drive: I:
 Free Space: 198.2 GB
File System: NTFS
      Model: WDC WD25 00JB-00G SCSI Disk Device
      Drive: F:
      Model: LITE-ON DVDRW SOHW-1693S SCSI CdRom Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/10/2004 06:00:00, 49536 bytes
      Drive: G:
      Model: LITE-ON LTR-52246S SCSI CdRom Device
      Drive: J:
      Model: NERO IMAGEDRIVE2 SCSI CdRom Device
System Devices
     Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_8086&DEV_29A1&SUBSYS_00000000&REV_02\3&11583659&0&08
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/10/2004 06:00:00, 68224 bytes
     Name: PCI standard host CPU bridge
Device ID: PCI\VEN_8086&DEV_29A0&SUBSYS_00000000&REV_02\3&11583659&0&00
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_284B&SUBSYS_81EC1043&REV_02\3&11583659&0&D8
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_2847&SUBSYS_00000000&REV_02\3&11583659&0&E4
Device ID: PCI\VEN_8086&DEV_2845&SUBSYS_00000000&REV_02\3&11583659&0&E3
Device ID: PCI\VEN_8086&DEV_2841&SUBSYS_00000000&REV_02\3&11583659&0&E1
Device ID: PCI\VEN_8086&DEV_283F&SUBSYS_00000000&REV_02\3&11583659&0&E0
     Name: SM Bus Controller
Device ID: PCI\VEN_8086&DEV_283E&SUBSYS_81EC1043&REV_02\3&11583659&0&FB
   Driver: n/a
     Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_8086&DEV_283A&SUBSYS_81EC1043&REV_02\3&11583659&0&D7
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/10/2004 06:00:00, 26624 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/10/2004 06:00:00, 142976 bytes
   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/3/2004 18:56:48, 74240 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/10/2004 06:00:00, 57600 bytes
   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/10/2004 06:00:00, 7168 bytes
Device ID: PCI\VEN_8086&DEV_2836&SUBSYS_81EC1043&REV_02\3&11583659&0&EF
     Name: Standard Universal PCI to USB Host Controller
Device ID: PCI\VEN_8086&DEV_2835&SUBSYS_81EC1043&REV_02\3&11583659&0&D1
   Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/10/2004 06:00:00, 20480 bytes
Device ID: PCI\VEN_8086&DEV_2834&SUBSYS_81EC1043&REV_02\3&11583659&0&D0
Device ID: PCI\VEN_8086&DEV_2832&SUBSYS_81EC1043&REV_02\3&11583659&0&EA
Device ID: PCI\VEN_8086&DEV_2831&SUBSYS_81EC1043&REV_02\3&11583659&0&E9
Device ID: PCI\VEN_8086&DEV_2830&SUBSYS_81EC1043&REV_02\3&11583659&0&E8
     Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_8086&DEV_2825&SUBSYS_81EC1043&REV_02\3&11583659&0&FD
   Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/10/2004 06:00:00, 25088 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/10/2004 06:00:00, 95360 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/10/2004 06:00:00, 3328 bytes
Device ID: PCI\VEN_8086&DEV_2820&SUBSYS_81EC1043&REV_02\3&11583659&0&FA
     Name: PCI standard ISA bridge
Device ID: PCI\VEN_8086&DEV_2810&SUBSYS_00000000&REV_02\3&11583659&0&F8
   Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/10/2004 06:00:00, 35840 bytes
     Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_F2\3&11583659&0&F0
     Name: JMicron JMB36X Controller
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_81E41043&REV_02\4&18CD42CE&0&00E4
   Driver: C:\WINDOWS\system32\DRIVERS\jraid.sys, 5.00.0001.0001 (English), 8/4/2006 02:29:24, 43904 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\JGOGO.sys, 5.00.3790.0001 (English), 2/7/2006 05:52:58, 6912 bytes
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_2363197B&REV_02\4&3736C399&0&00E1
     Name: Ethernet Controller
Device ID: PCI\VEN_11AB&DEV_1FAA&SUBSYS_6B001385&REV_03\4&1FAF5EA3&0&08F0
   Driver: n/a
     Name: Creative SB X-Fi
Device ID: PCI\VEN_1102&DEV_0005&SUBSYS_00211102&REV_00\4&1FAF5EA3&0&10F0
   Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 00:56:44, 4096 bytes
   Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 00:56:58, 130048 bytes
   Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/3/2004 23:15:22, 140928 bytes
   Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
   Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
   Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/3/2004 23:08:04, 48640 bytes
   Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 00:56:58, 23552 bytes
   Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.1187 (English), 8/17/2006 11:14:24, 502272 bytes
   Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.1187 (English), 8/17/2006 11:17:10, 500480 bytes
   Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.1187 (English), 8/17/2006 11:15:00, 116224 bytes
   Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.1187 (English), 8/17/2006 11:17:12, 7168 bytes
   Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.1187 (English), 8/17/2006 11:14:42, 143872 bytes
   Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.1187 (English), 8/17/2006 11:14:38, 78336 bytes
   Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.1187 (English), 8/17/2006 11:15:24, 765952 bytes
   Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.1187 (English), 8/17/2006 11:15:32, 154112 bytes
   Driver: C:\WINDOWS\system32\drivers\haP17v2k.sys, 5.12.0001.1187 (English), 8/17/2006 11:15:38, 180224 bytes
   Driver: C:\WINDOWS\system32\drivers\ha20x2k.sys, 5.12.0001.1187 (English), 8/17/2006 11:16:32, 1110528 bytes
   Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0012 (English), 8/17/2006 11:32:56, 8192 bytes
   Driver: C:\WINDOWS\system32\ctdlang.dat, 8/17/2006 11:22:58, 323640 bytes
   Driver: C:\WINDOWS\system32\ctdnlstr.dat, 8/17/2006 11:22:58, 44567 bytes
   Driver: C:\WINDOWS\system32\ctstatic.dat, 8/17/2006 11:11:10, 313207 bytes
   Driver: C:\WINDOWS\system32\ctdaught.dat, 8/17/2006 11:11:10, 53932 bytes
   Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 8/17/2006 11:32:46, 33792 bytes
   Driver: C:\WINDOWS\system32\commonfx.dll, 5.12.0001.1187 (English), 8/17/2006 11:20:36, 87552 bytes
   Driver: C:\WINDOWS\system32\ctaudfx.dll, 5.12.0001.1187 (English), 8/17/2006 11:20:48, 536576 bytes
   Driver: C:\WINDOWS\system32\ctsblfx.dll, 5.12.0001.1187 (English), 8/17/2006 11:21:30, 548352 bytes
   Driver: C:\WINDOWS\system32\cteapsfx.dll, 5.12.0001.1187 (English), 8/17/2006 11:21:12, 160768 bytes
   Driver: C:\WINDOWS\system32\CTEXFIFX.dll, 5.12.0001.1187 (English), 8/17/2006 11:21:44, 1170432 bytes
   Driver: C:\WINDOWS\system32\CTHWIUT.DLL, 5.12.0001.1187 (English), 8/17/2006 11:22:02, 61952 bytes
   Driver: C:\WINDOWS\system32\CT20XUT.DLL, 5.12.0001.1187 (English), 8/17/2006 11:22:00, 158720 bytes
   Driver: C:\WINDOWS\system32\ctemupia.dll, 5.12.0001.1187 (English), 8/17/2006 11:22:02, 108032 bytes
   Driver: C:\WINDOWS\system32\piaproxy.dll, 5.12.0001.1187 (English), 8/17/2006 11:14:28, 73728 bytes
   Driver: C:\WINDOWS\system32\ctdproxy.dll, 5.12.0001.1187 (English), 8/17/2006 11:16:38, 71680 bytes
   Driver: C:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English), 8/17/2006 11:14:50, 21504 bytes
   Driver: C:\WINDOWS\system32\data\cts20x.dat, 8/17/2006 11:11:10, 2091 bytes
   Driver: C:\WINDOWS\system32\data\ctd20x.dat, 8/17/2006 11:11:10, 15899 bytes
   Driver: C:\WINDOWS\system32\SBXFi.ico, 2/7/2005 17:45:22, 766 bytes
   Driver: C:\WINDOWS\system32\XFi.bmp, 2/7/2005 17:45:22, 3128 bytes
   Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0002.0036 (English), 8/17/2006 11:33:36, 81920 bytes
   Driver: C:\WINDOWS\system32\ctdvinst.dll, 0.04.0000.0036 (English), 8/17/2006 11:33:36, 146432 bytes
   Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0461 (English), 8/17/2006 11:23:00, 340176 bytes
     Name: Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_81681043&REV_01\4&935E26E&0&00E3
   Driver: C:\WINDOWS\system32\DRIVERS\Rtenicxp.sys, 5.646.0727.2006 (English), 7/26/2006 19:49:10, 83712 bytes
     Name: NVIDIA GeForce 8800 GTS
Device ID: PCI\VEN_10DE&DEV_0193&SUBSYS_C8213842&REV_A2\4&2B9C2F50&0&0008
   Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 5747488 bytes
   Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 5745536 bytes
   Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 168004 bytes
   Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.9792 (), 12/21/2006 11:29:00, 581632 bytes
   Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 274432 bytes
   Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 6500352 bytes
   Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 7774208 bytes
   Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 81920 bytes
   Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 81920 bytes
   Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11068 (English), 12/21/2006 11:29:00, 286720 bytes
   Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 229376 bytes
   Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 5623808 bytes
   Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 5246976 bytes
   Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 3072000 bytes
   Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 3211264 bytes
   Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 188416 bytes
   Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 458752 bytes
   Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 888832 bytes
   Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 2854912 bytes
   Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 2932736 bytes
   Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 3006464 bytes
   Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 2043904 bytes
   Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0010.9792 (English), 12/21/2006 11:29:00, 2465792 bytes
   Driver: C:\WINDOWS\help\nvcpl.hlp, 12/21/2006 11:29:00, 177897 bytes
   Driver: C:\WINDOWS\help\nvwcplen.hlp, 12/21/2006 11:29:00, 55444 bytes
   Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 12/21/2006 11:29:00, 35840 bytes
   Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 12/21/2006 11:29:00, 35840 bytes
DirectX Components
   ddraw.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 266240 bytes
 ddrawex.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 8/10/2004 06:00:00 10496 bytes
    d3d8.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 1179648 bytes
 d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 8192 bytes
    d3d9.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 8/10/2004 06:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 825344 bytes
 d3dramp.dll: 5.01.2600.0000 English Final Retail 8/10/2004 06:00:00 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 8/10/2004 06:00:00 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 8/10/2004 06:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/10/2004 06:00:00 34816 bytes
   dplay.dll: 5.00.2134.0001 English Final Retail 8/10/2004 06:00:00 33040 bytes
  dplayx.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 23552 bytes
 dpwsock.dll: 5.00.2134.0001 English Final Retail 8/10/2004 06:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 30208 bytes
  dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 18432 bytes
   dpnet.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 3584 bytes
 dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 3584 bytes
 dpvoice.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 83456 bytes
  dpvvox.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 116736 bytes
  dpvacm.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/10/2004 06:00:00 53520 bytes
  dinput.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 159232 bytes
 dinput8.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 181760 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 8/10/2004 06:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/10/2004 06:00:00 394240 bytes
     joy.cpl: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 68608 bytes
   gcdef.dll: 5.01.2600.0000 English Final Retail 8/10/2004 06:00:00 76800 bytes
     pid.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 35328 bytes
  dsound.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 1294336 bytes
  dswave.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 19456 bytes
   dsdmo.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 71680 bytes
  dmusic.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 104448 bytes
  dmband.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 61440 bytes
   dmime.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 35840 bytes
 dmstyle.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 105984 bytes
 dmsynth.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 82432 bytes
  system.dll: 1.00.3705.6018 English Final Retail 1/29/2007 20:23:41 1179648 bytes
  system.dll: 1.01.4322.2032 English Final Retail 1/29/2007 21:57:55 1224704 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 2/6/2007 22:15:51 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 2/6/2007 22:15:46 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 2/6/2007 22:15:47 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 2/6/2007 22:15:48 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 2/6/2007 22:15:48 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 2/6/2007 22:15:48 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 2/6/2007 22:15:49 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 2/6/2007 22:15:49 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 2/6/2007 22:15:49 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 2/6/2007 22:15:50 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 2/6/2007 22:15:51 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 2/6/2007 22:15:51 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 2/6/2007 22:15:51 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 2/6/2007 22:15:51 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 2/6/2007 22:15:51 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 2/6/2007 22:15:50 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 2/6/2007 22:15:50 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 2/6/2007 22:15:50 223232 bytes
   dx7vb.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 619008 bytes
   dx8vb.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 1227264 bytes
 dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 2113536 bytes
   mfc40.dll: 4.01.0000.6140 English Final Retail 8/10/2004 06:00:00 924432 bytes
   mfc42.dll: 6.02.4131.0000 English Final Retail 8/10/2004 06:00:00 1028096 bytes
 wsock32.dll: 5.01.2600.2180 English Final Retail 8/10/2004 06:00:00 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/10/2004 06:00:00 70656 bytes
 devenum.dll: 6.05.2600.2180 English Final Retail 8/10/2004 06:00:00 59904 bytes
  dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/10/2004 06:00:00 35328 bytes
 mpg2splt.ax: 6.05.2710.2732 English Final Retail 8/5/2005 13:06:50 165376 bytes
   msdmo.dll: 6.05.2600.2180 English Final Retail 8/10/2004 06:00:00 14336 bytes
  encapi.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 20480 bytes
    qasf.dll: 10.00.0000.4332 English Final Retail 8/3/2005 18:29:52 221184 bytes
    qcap.dll: 6.05.2600.2180 English Final Retail 8/10/2004 06:00:00 192512 bytes
     qdv.dll: 6.05.2600.2180 English Final Retail 8/10/2004 06:00:00 279040 bytes
    qdvd.dll: 6.05.2600.2709 English Final Retail 6/28/2005 19:55:07 385024 bytes
   qedit.dll: 6.05.2600.2180 English Final Retail 8/10/2004 06:00:00 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/10/2004 06:00:00 733696 bytes
  quartz.dll: 6.05.2600.2749 English Final Retail 8/29/2005 22:13:42 1287680 bytes
 strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 09:52:08 246814 bytes
 iac25_32.ax: 2.00.0005.0053 English Final Retail 8/10/2004 06:00:00 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 8/10/2004 06:00:00 848384 bytes
 ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/10/2004 06:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/10/2004 06:00:00 338432 bytes
 ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/10/2004 06:00:00 755200 bytes
 ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/10/2004 06:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/10/2004 06:00:00 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/10/2004 06:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/10/2004 06:00:00 204288 bytes
      ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
  ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
  ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
  stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
   mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
 mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
  swenum.sys: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 4352 bytes
   mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5504 bytes
  msdvbnp.ax: 6.05.2710.2732 English Final Retail 8/5/2005 14:01:54 58368 bytes
psisdecd.dll: 6.05.2710.2732 English Final Retail 8/5/2005 14:01:54 239104 bytes
 psisrndr.ax: 6.05.2710.2732 English Final Retail 8/5/2005 14:02:00 224256 bytes
   ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 16384 bytes
mpeg2data.ax: 6.05.2710.2732 English Final Retail 8/5/2005 14:01:54 62976 bytes
  ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 10880 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 15360 bytes
msvidctl.dll: 6.05.2710.2732 English Final Retail 8/5/2005 14:01:54 1669120 bytes
    slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:30 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 17024 bytes
  vbisurf.ax: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 30720 bytes
   msyuv.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 17408 bytes
 kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 61952 bytes
   ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 43008 bytes
 kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 90624 bytes
vfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:48 53760 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/10/2004 06:00:00 50688 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
CC Decoder,0x00200000,2,1,,5.03.2600.2180
WST Codec,0x00200000,1,1,,5.03.2600.2180
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,6.05.0001.0000
Nero Audible Decoder,0x00200000,1,1,NeAudible.ax,4.06.0015.0000
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Vorbis Decoder,0x00600000,1,1,OggDS.dll,0.09.0009.0005
Pinnacle Real Media Renderer 2,0x00200000,2,0,PCLERMRenderer2.ax,1.00.0000.0007
NVIDIA Video Post Processor,0x00200001,1,1,nvvpp.ax,1.00.0058.0000
Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,2.01.0001.0000
Nero Subpicture Decoder,0x00400000,1,1,NeSubpicture.ax,4.06.0015.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
PushSink,0x00200000,1,0,pushSink.ax,8.00.0000.0000
Panasonic MXF Sink Filter,0x00200000,1,0,PFSink.ax,0.00.0010.0000
ESink,0x00200000,1,0,ESink.ax,2.00.0000.0001
CT Upsampler filter,0x00100000,1,1,Upsample.ax,2.00.0005.0000
Pinnacle MPADecoder,0x00400000,1,1,MPADecoder.ax,2.01.0000.0002
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,4.06.0015.0000
Nero Stream Buffer Sink,0x00200000,0,0,NeSBE.ax,4.06.0015.0000
Nero Subtitle,0x00200000,1,1,NeSubtitle.ax,4.06.0015.0000
NVIDIA Cd Audio Reader,0x00200000,0,1,NvCdaRdr.ax,1.00.0058.0000
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,3.01.0004.0000
Pinnacle Video Renderer,0x00200000,1,0,pcle_ovr.ax,6.00.0052.0000
WST Renderer,0x00800000,1,1,WSTRenderer.ax,6.05.2710.2732
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Smart3D Video Effect Filter,0x00200000,1,1,NSG_dxFilter.dll,1.07.0005.0000
Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,3.00.0000.0000
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0004.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
Pinnacle MPEG Layer-1/2 Audio Decoder,0x00400000,1,1,PCLEMPEGBox.ax,5.00.0135.0000
Pinnacle ASF Audio Source,0x00200000,0,0,PCLEASFMediaSource.ax,1.00.0002.0018
Pinnacle Cutlist Audio Source 3,0x00200000,0,0,PCLECutlistSource3.ax,3.00.0000.0039
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.4332
Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,3.00.0000.0000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
BPM Metadata,0x001fffff,1,1,MetaBPM.ax,1.00.0004.0000
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Pinnacle Infinite Pin Tee,0x00200000,1,1,pinftee.ax,9.00.0019.0000
Pinnacle LPCM PCM Transform Filter,0x00200000,0,0,PCLELPCMTransform.ax,1.00.0002.0003
MediaSampleGrab,0x00200000,1,1,FrameGrab.ax,2.00.0000.0000
Pinnacle(dicas) MPEG-4 Multiplexer,0x00200000,1,1,pclempeg4mux.ax,1.05.0039.0000
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Nero FTC,0x00200000,1,1,NeFTC.ax,1.00.0000.0000
Pinnacle MPEG Encoder,0x00200000,1,1,PcleMpegEnc.ax,4.00.0000.0012
BPM Metadata,0x001fffff,1,1,MetaBPMu.ax,2.00.0002.0000
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
Pinnacle(dicas) MPEG-4 Video Decoder,0x00200001,1,1,pclempeg4viddec.ax,1.09.0037.0000
Emuzed Flow Control,0x00200000,1,1,FlowCtrl.ax,2.00.0000.0001
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2710.2732
Pinnacle DVD Data Streamer Filter,0x00200000,1,1,,
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.03.0006.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2710.2732
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
NVIDIA VOB Parser,0x00200000,1,0,nvtsvobparse.ax,1.00.0058.0000
Microsoft TV Caption Decoder,0x00600000,1,0,MSTVCapn.dll,5.01.2710.2732
Nero Resize,0x00400000,1,1,NeResize.ax,4.06.0015.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
ESinkAudio,0x00200000,1,0,ESinkAudio.ax,1.00.0000.0000
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
Pinnacle(dicas) MPEG-4 Audio Decoder,0x00200001,1,1,pclempeg4auddec.ax,1.06.0036.0000
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
SVM Metadata,0x001fffff,1,1,MetaSVM.ax,1.00.0006.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
Pinnacle MPEG Layer 1-3 Audio Decoder,0x00400000,1,1,PCLEMPADecoder.ax,1.00.0000.0029
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Nero AV Synchronizer,0x00200000,1,1,NeAVSync.ax,4.06.0015.0000
VBI Codec,0x00600000,1,4,VBICodec.ax,6.05.2710.2732
Pinnacle Audio Codec,0x00600000,1,1,PcleAudioCodec.ax,1.00.0067.0000
Pinnacle AC3 Audio Source,0x00200000,0,0,PCLEAC3MediaSource.ax,1.00.0002.0010
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,4.06.0015.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2710.2732
Pinnacle Image Scaler,0x00200000,1,1,pcleCSC.ax,2.04.0077.0000
Pinnacle AC3 Encoder (5.1 Channels),0x00200000,1,1,PcleAC3Enc5_1Ch.ax,1.00.0006.0000
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,4.06.0015.0000
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,4.06.0015.0000
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,4.06.0015.0000
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,4.06.0015.0000
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,4.06.0015.0000
Pinnacle Cutlist Video Source 3,0x00200000,0,0,PCLECutlistSource3.ax,3.00.0000.0039
Pinnacle MPEG4 Video Source,0x00200000,0,0,PCLEMPEG4MediaSource.ax,1.00.0002.0063
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.06.0015.0000
Nero Smart3D Transition Effect Filter,0x00200000,1,1,NSG_dxFilter.dll,1.07.0005.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
Pinnacle Single Audio Source,0x00200000,0,0,PCLESingleSource.ax,1.00.0002.0025
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,4.06.0015.0000
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,4.06.0015.0000
Nero Overlay Mixer,0x00200000,1,1,NeOverlayMixer.ax,4.06.0015.0000
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Nero MP4 Splitter,0x00600000,1,1,NeMP4Splitter.ax,4.06.0015.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Nero Video Decoder HD,0x00400000,1,2,NeVideoHD.ax,4.06.0015.0000
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
HighMAT and MPV Navigator Filter,0x00200000,0,3,HMNavigator.ax,4.06.0015.0000
AC3 from AVI XForm,0x00680000,1,1,Decaudio.ax,2.02.0000.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,4.06.0015.0000
Pinnacle Video AntiJitter,0x00200000,1,1,pcleCSC.ax,2.04.0077.0000
Pinnacle Scene Detect Filter,0x00200000,0,0,DWSceneDetect2.ax,15.00.0002.0015
Pinnacle Single Video Source,0x00200000,0,0,PCLESingleSource.ax,1.00.0002.0025
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle(dicas) MPEG-4 File Reader,0x00200000,0,1,pclemp4filereader.ax,1.05.0035.0000
PICVideo M-JPEG 3 DirectShow Decompressor,0x00800001,1,1,pvmjpg30.dll,3.00.0000.0012
Pinnacle MPEG Video Decoder (P),0x00400000,1,1,PcleMpegDec.ax,1.07.0000.0022
PCM to EXT,0x00200000,0,0,Pcm2Ext.ax,6.00.0002.0000
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,4.06.0015.0000
Stream Control Filter,0x001fffff,1,1,StreamCon.ax,1.00.0000.0001
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle MPEG4 Audio Source,0x00200000,0,0,PCLEMPEG4MediaSource.ax,1.00.0002.0063
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,4.06.0015.0000
CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0007.0000
Pinnacle MPEG2 Demux II (MovieBox USB version),0x00200000,1,2,PcleDemux2MBox.ax,2.00.0001.0004
NVIDIA Teletext Decoder,0x00200000,1,1,nvttxdec.ax,1.00.0058.0000
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0004.0000
Pinnacle MCE Multiplexer,0x00200000,2,1,PCLEMPEGBox.ax,5.00.0135.0000
Creative AC3 Source Filter,0x00400000,0,1,AC3Srcu.ax,3.01.0001.0000
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,4.06.0015.0000
NVIDIA TS Info Parser,0x00200000,1,1,nvtsinfo.ax,1.00.0058.0000
Creative PCM Raw Writer,0x00200000,1,0,RawWritu.ax,1.00.0000.0000
Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,3.01.0003.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
Nero Smart3D Text Effect Filter,0x00200000,1,1,NSG_dxFilter.dll,1.07.0005.0000
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
Pinnacle Video Block Filter,0x00200000,1,1,pcleCSC.ax,2.04.0077.0000
Nero Video Renderer,0x00200000,1,0,NeVideoRenderer.ax,4.06.0015.0000
Nero PresentationGraphics Decoder,0x00600000,2,1,NeBDGraphic.ax,4.06.0015.0000
CT PDP filter,0x00100000,1,1,PDP.ax,1.00.0008.0000
Pinnacle MPEG Layer-2 Audio Encoder,0x00200000,1,1,PCLEMPAEncoder.ax,2.00.0000.0014
Pinnacle MPEG Source 2,0x00200000,0,3,PCLEMPEGSource2.ax,2.00.0002.0041
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
NVIDIA Audio Decoder,0x00800001,1,1,nvauddec.ax,4.00.0058.0000
Peak Follower Filter,0x001fffff,1,1,PassPeak.ax,1.00.0000.0003
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,12,NeDVD.ax,4.06.0015.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2710.2732
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2709
Pinnacle Time Fixer Filter,0x00200000,0,0,TimeFixer2.ax,1.00.0002.0007
Nero InteractiveGraphics Decoder,0x00600000,1,1,NeBDGraphic.ax,4.06.0015.0000
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
Pinnacle Image Converter,0x00200000,1,1,pcleCSC.ax,2.04.0077.0000
Pinnacle VideoInfo Changer Filter,0x00200000,0,0,VideoInfoChanger2.ax,1.00.0002.0007
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
NVIDIA Video Decoder,0x00800001,2,3,nvviddec.ax,4.00.0058.0000
Pinnacle AC3 Encoder (2 Channels),0x00200000,1,1,PcleAC3Enc2Ch.ax,1.00.0006.0000
Nero Sound Processor,0x00200000,1,1,NeSoundProc.ax,4.06.0015.0000
NVIDIA HDTV Demux,0x00400000,1,2,nvhdtvdemux.ax,1.00.0058.0000
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,4.06.0015.0000
Pinnacle AVI Video Source,0x00200000,0,0,PCLEAVIMediaSource.ax,1.00.0002.0039
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,4.06.0015.0000
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.05.0001.0000
Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,3.00.0002.0000
LEAD MCMP/MJPEG Decoder,0x00800000,1,1,LCODCCMP.DLL,
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0005.0000
Creative Audio Gain Filter,0x00200000,1,1,AudGain.ax,1.00.0000.0000
Pinnacle File Writer,0x00200000,1,0,mpegrender.ax,1.00.0000.0014
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.4332
AC3 Prologic Decoder    ,0x03680000,1,1,Ac3audio.ax,2.02.0000.0000
CBVA Filter,0x00200000,1,1,CBVAFilter.dll,5.01.2700.2180
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,4.06.0015.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,3.00.0002.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Creative Flac Source Filter,0x00400000,0,1,FlacSrcu.ax,1.00.0000.0000
Nero Audio Decoder 2,0x00600000,1,1,NeAudio2.ax,4.06.0015.0000
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,4.06.0015.0000
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
AudSkip Filter,0x001fffff,1,1,AudSkip.ax,1.00.0000.0004
Creative MLP Source Filter,0x00400000,0,1,MlpSrcu.ax,3.01.0000.0000
Vorbis Encoder,0x00200000,1,1,OggDS.dll,0.09.0009.0005
Pinnacle MPEG Layer-2 Audio Encoder,0x00200000,1,1,PCLEMPEGBox.ax,5.00.0135.0000
SVM Metadata,0x001fffff,1,1,MetaSVMu.ax,2.00.0002.0000
Nero Stream Buffer Source,0x00200000,0,0,NeSBE.ax,4.06.0015.0000
Ogg Multiplexer,0x00400000,1,1,OggDS.dll,0.09.0009.0005
CT HPVirtualizer filter,0x00100000,1,1,Virtual.ax,1.00.0000.0000
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,4.06.0015.0000
Pinnacle MP3 Audio Source,0x00200000,0,0,PCLEMP3MediaSource.ax,1.00.0002.0011
Pinnacle MPEG Audio Source,0x00200000,0,0,PCLEMPEGMediaSource.ax,1.00.0002.0040
Pinnacle AVI Audio Source,0x00200000,0,0,PCLEAVIMediaSource.ax,1.00.0002.0039
Pinnacle(dicas) MPEG-4 File Writer,0x00200000,1,0,pclemp4filewriter.ax,1.05.0035.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
Pinnacle Video Deinterlacer,0x00200000,1,1,pcleCSC.ax,2.04.0077.0000
Pinnacle WAV Audio Source,0x00200000,0,0,PCLEWAVMediaSource.ax,1.00.0002.0010
Pinnacle MP3 Encoder,0x00200000,1,1,PcleMP3Encoder.ax,9.03.0000.0005
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2709
PICVideo M-JPEG 3 DirectShow Compressor,0x00100000,1,1,pvmjpg30.dll,3.00.0000.0012
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2709
NVIDIA PVR File Source,0x00600000,0,2,nvtsread.ax,1.00.0058.0000
Pinnacle Silencer,0x00200000,0,0,PCLESilencer.ax,1.00.0002.0003
Nero Splitter,0x00600000,1,3,NeSplitter.ax,4.06.0015.0000
Nero Deinterlace,0x00200000,1,1,NeDeinterlace.ax,4.06.0015.0000
AC3Filter,0x40000000,1,1,ac3filter.ax,0.07.0000.0000
CT CMSS3 filter,0x00100000,1,1,CMSS3.ax,3.00.0013.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
Pinnacle MPEG Video Source,0x00200000,0,0,PCLEMPEGMediaSource.ax,1.00.0002.0040
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,4.06.0015.0000
AudioResampler,0x00200000,1,1,AudioResampler.ax,2.01.0068.0000
Pinnacle ASF Video Source,0x00200000,0,0,PCLEASFMediaSource.ax,1.00.0002.0018
Pinnacle MPEG2 Demux II,0x00200000,1,2,pcledemux2.ax,2.00.0000.0212
WST Pager,0x00800000,1,1,WSTPager.ax,6.05.2710.2732
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle DV Decoder,0x00200000,1,1,PCLEDVBox.ax,2.02.0069.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2710.2732
Creative Ogg Source Filter,0x00400000,0,1,OggSrcu.ax,1.00.0001.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Creative NVF Filter,0x00400000,0,1,NvfSrcu.ax,3.01.0001.0000
Pinnacle Sample Sink,0x00200000,0,0,PCLESampleSink.ax,1.00.0002.0020
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Creative PCM Raw Writer,0x00200000,1,0,RawWrit.ax,1.00.0000.0000
Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0004.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
Pinnacle Audio / Video synchronisation filter,0x00200000,2,2,PCLESync.ax,1.01.0000.0005
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,4.06.0015.0000
Pinnacle MPEG 2 Decoder,0x00400000,2,1,PCLEMPEGBox.ax,5.00.0135.0000
Nero Video Decoder,0x00600000,2,1,NeVideo.ax,4.06.0015.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Nero Sound Switcher,0x00200000,1,1,NeSoundSwitch.ax,4.06.0015.0000
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,5.00.0001.0000
NVIDIA MultiSource Filter,0x00000000,0,1,NvMultiSource.ax,1.00.0058.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.05.2710.2732
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,4.06.0015.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2710.2732
AXWavRender,0x00200000,1,0,axwavrender.ax,4.02.0000.0001
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Nero Thumbnail Decoder,0x00600000,1,1,NeBDThumbnail.ax,4.06.0015.0000
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,3.01.0001.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2709
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,4.06.0015.0000
Pinnacle MPEG 2 Splicer,0x00200000,2,3,PCLEMPEGBox.ax,5.00.0135.0000
Nero Stream Control,0x00200000,1,1,NeStreamControl.ax,1.00.0000.0000
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Sample Queue,0x00200000,1,1,NeSampleQueue.ax,1.00.0000.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
Pinnacle MPEG Demuxer,0x00200000,1,3,PcleMPGDemux.ax,5.00.0010.0000
Pinnacle MPEG 2 Multiplexer,0x00200000,2,1,PCLEMPEGBox.ax,5.00.0135.0000
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Pinnacle DV Encoder,0x00200000,1,1,PCLEDVBox.ax,2.02.0069.0000
AVSynChronizer Filter,0x00200000,2,2,AVSynChronizer.ax,2.00.0000.0005
Nero File Source,0x00200000,0,1,NeFileSrc.ax,4.06.0015.0000
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.06.0015.0000
Pinnacle NEOVideoRepair,0x00200000,2,2,PCLENeoVideoRepair.ax,2.00.0000.0001
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,4.06.0015.0000
Nero Ogg Splitter,0x00400000,1,1,NeOggSplitter.ax,4.06.0015.0000
Nero DVD Decoder,0x00600000,2,1,NeVideo.ax,4.06.0015.0000
NVIDIA Navigator,0x00600000,0,3,nvnav.ax,1.00.0058.0000
Pinnacle MPEG 2 Encoder,0x00200000,1,1,PCLEMPEGBox.ax,5.00.0135.0000
Nero Digital Parser,0x00600000,0,3,NDParser.ax,4.06.0015.0000
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
NVIDIA ATSC File,0x00200000,0,1,nvatscfile.ax,1.00.0058.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle AC3 Decoder,0x00800000,1,1,PcleAC3Decoder.ax,1.00.0047.0000
Nero MP3 Encoder,0x00200000,1,1,NeMp3Encoder.ax,4.06.0015.0000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,3.00.0002.0000
NVIDIA PVR Demultiplexer,0x00600000,1,2,nvtsdemux.ax,1.00.0058.0000
Creative LiveRecording Filter SxS,0x00400000,0,1,LiveRecu.ax,5.00.0001.0000
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,4.06.0015.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Ogg Splitter,0x00600000,1,1,OggDS.dll,0.09.0009.0005
Creative Internet Source Filter,0x00400000,0,1,InetSrcu.ax,1.00.0000.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,4.06.0015.0000
Pinnacle(dicas) MPEG-4 Audio Encoder,0x00200000,1,1,pclempeg4audenc.ax,1.06.0035.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
HighMAT/MPV Navigator Client Filter,0x00200000,0,0,HMNavigator.ax,4.06.0015.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,4.06.0015.0000
Pinnacle file sink 2,0x00200000,0,0,DWSink2.ax,20.00.0000.0005
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
AudioGrab,0x00200000,1,1,AudioGrab.ax,1.00.0000.0002
Pinnacle CSC,0x00200000,1,1,pcleCSC.ax,2.04.0077.0000
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Encoder Devices:
Angel USB Encoder,0x00200000,3,0,,5.03.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
LEAD MCMP/MJPEG Codec,0x00100000,1,1,LCODCCMP.DLL,
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 5.2.1 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
LEAD MCMP/MJPEG Codec (VFW),0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
PICVideo M-JPEG 3 VfW Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
SB X-Fi Audio [BC00],0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
SB X-Fi MIDI Port [BC00],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB X-Fi Synth A [BC00],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB X-Fi Synth B [BC00],0x00200000,1,0,quartz.dll,6.05.2600.2749
 Pinnacle Auxiliary Filters:
Pinnacle AC3 Decoder,0x00200000,1,1,PcleAC3Decoder.ax,1.00.0047.0000
Pinnacle Audio Codec,0x00200000,1,1,PcleAudioCodec.ax,1.00.0067.0000
Pinnacle MPEG 2 Decoder,0x00200000,2,1,PCLEMPEGBox.ax,5.00.0135.0000
Pinnacle MPEG Layer-1/2 Audio Decoder,0x00200000,1,1,PCLEMPEGBox.ax,5.00.0135.0000
Pinnacle MPEG Source 2,0x00200000,0,0,PCLEMPEGSource2.ax,2.00.0002.0041
Pinnacle Real Media Renderer 2,0x00200000,0,0,PCLERMRenderer2.ax,1.00.0000.0007
WDM Streaming Capture Devices:
SB X-Fi MIDI Port [BC00],0x00200000,2,2,,5.03.2600.2180
SB X-Fi Audio [BC00],0x00200000,3,2,,5.03.2600.2180
Angel USB MPEG Device,0x00200000,5,0,,5.03.2600.2180
WDM Streaming Rendering Devices:
SB X-Fi DMusic Synth [BC00],0x00200000,1,1,,5.03.2600.2180
SB X-Fi Synth A [BC00],0x00200000,1,1,,5.03.2600.2180
SB X-Fi Synth B [BC00],0x00200000,1,1,,5.03.2600.2180
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
BDA Network Providers:
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.05.2710.2732
WDM Streaming Multiplexer Devices:
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.05.2710.2732
WDM Streaming TV Tuner Devices:
Angel USB TvTuner,0x00200000,0,2,,5.03.2600.2180
WDM Streaming Crossbar Devices:
Angel USB Crossbar,0x00200000,5,2,,5.03.2600.2180
WDM Streaming TV Audio Devices:
Angel USB TvAudio,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2710.2732
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2710.2732
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2710.2732
WDM Streaming Communication Transforms:
Audio Renderers:
SB X-Fi Audio [BC00],0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: SB X-Fi Audio [BC00],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming System Devices:
SB X-Fi Synth A [BC00],0x00200000,10,2,,5.03.2600.2180
SB X-Fi Audio [BC00],0x00200000,12,2,,5.03.2600.2180
BDA Receiver Component:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.2180
I would try it again in full screen mode and put your native desktop resolution at 1024 to test it.. it looks like your in 1600, also play around with vsync ?
None of that is going to get the game to run...it just doesn't work, trust me there are plenty of sources on the matter.
My current problem is getting the computer to run programs in window mode, and it wont do it.
