- Aug 27, 2002
- The OCFORUMS
Well, the first time I ever watercooled, I bought the parts, then got out the powertools and made it all fit. Radiator mounting is an excelent excuse to get out the jigsaw.
greenmaji said:Uhh.. you dont know what Intel can do apparntly.. maybe you should go check out Ross's and FUGGERS 3d benchmarks
aao_pwner said:But to answer that other guy's question. It's like the first time, i didnt build a computer, i got one premade yes, then i started learning on how to modify it and stuff, so i baught new parts for it as i needed them, got my experence from doing that, then just started building computers all together. I have a different mentallity than most, also, I'm a freelance web designer/programmer, i have like 7K to throw at this.
Ok, how about this, I have NO idea what custom parts to get, that's why i'm getting a kit.
Can you guys suggest a group of parts for me to get like, radiator, pump, and make sure the tube sizes are correct lol because i have no idea when it comes to plumbing. Also, i'm cooling 2 GPU's and a processor, so make sure you get good blocks for thoes too.
aaronjb said:Oh yeah, sure. Don't do any research, don't read the stickies, don't read archived posts - just ask someone else to do all the footwork for you. The "7K to throw at this" quote is where I stopped reading your post. You won't get much help with that juvenille attitude.
If you spend time researching this yourself, you'll be better off in the end. Not only will you have a (potentially) great setup, you'll also be able to take a little more pride in what you've done. If you just want to own the latest and greatest and not care how it works, then I'm afraid most folks here won't offer much help.
aao_pwner said:And I have no idea what tubing i will need, nor adapters, i dont know much about the tubing aspect of the whole deal, thats where im having the most problems.
greenmaji said:What did your reaserch tell you about tubing and plumbing exactly?
Links to things you read about pluming? (to insure acuracy of information of course )
