[b][u]GIGABYTE GA-EP45-UD3R[/u][/b]
[u][b][u]MB Intelligent Tweaker(M.I.T.)[/u][/b]
Robust Graphics Booster ...............:
CPU Clock Ratio ..........................:
Fine CPU Clock Ratio.....................:.
CPU Frequency ...........................: Mhz
[b][u]Clock Chip Control [/u][/b]
[b][u]Standard Clock Control[/u][/b]
CPU Host Clock Control..................: [Enabled] [Disabled]
CPU Host Frequency (Mhz) ............:Mhz
PCI Express Frequency (Mhz) .........:Mhz
C.I.A. 2......................................: Disabled
[b][u]Advanced Clock Control [Press Enter][/u][/b]
CPU Clock Drive...........................: mv
PCI Express Clock Drive.................: mv
CPU Clock Skew (ps)....................: ps
MCH Clock Skew (ps)...................: ps
[b][u]DRAM Performance Control[/u][/b][u][/u]
Performance Enhance...................: [Turbo]
Extreme Memory Profile (X.M.P.).....:
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............:
Memory Frequency (Mhz) ..............: Mhz
DRAM Timing Selectable ................: [Manual]
[b]Standard Timing Control[/b]
CAS Latency Time..............................:
tRCD .........................................:
tRP...........................................:
tRAS..........................................:
[b]Advanced Timing Control [Press Enter][/b]
tRRD...........................................:
tWTR..........................................:
tWR............................................:
tRFC...........................................:
tRTP...........................................:
Command Rate (CMD) ....................:
[b]Channel A[/b]
[b]Channel A Timings Settings [Press Enter][/b]
Static tRead Value.........................:Auto
tRD Phase0 Adjustmen.......................:Auto
tRD Phase1 Adjustment......................:Auto
tRD Phase2 Adjustment .....................:Auto
tRD Phase3 Adjustment......................:Auto
Trd2rd(Different Rank).....................:Auto
Twr2wr(Different Rank).....................:Auto
Twr2rd(Different Rank).....................:Auto
Trd2wr(Same/Diff Rank).....................:Auto
Dimm1 Clock Skew Control...................:Auto ps
Dimm2 Clock Skew Control...................:Auto ps
DDR Write Training ...........................: Enabled
[b]Channel A Driving Settings [Press Enter][/b]
Driving Strength Profile...................:[AUTO],[667Mhz],[800Mhz],[1066Mhz],[OC-1200],[OC-1333]
Data Driving Pull-Up Level.................:Auto
Cmd Driving Pull-Up Level..................:Auto
Ctrl Driving Pull-Up Level.................:Auto
Clk Driving Pull-Up Level..................:Auto
Data Driving Pull-Down Level...............:Auto
Cmd Driving Pull-Down Level................:Auto
Ctrl Driving Pull-Down Level...............:Auto
Clk Driving Pull-Down Level................:Auto
[b]Channel B[/b]
[b]Channel B Timings Settings [Press Enter][/b]
DDR Write Training .........................: Enabled
[b]Channel B Driving Settings [Press Enter][/b]
[b]{U]Motherboard Voltage Control[/b]{/U]
Voltage Type.………... Normal
[b]CPU[/b]
Load Line Calibration......................: [Enabled] [Disabled]
CPU Vcore..................................:v
CPU Termination…..... 1.200V*..............:v
CPU PLL...............1.500V*..............: v
CPU Reference.........0.755V*..............: v
[b]MCH/ICH[/b]
MCH Core..............1.100V...............: v
MCH Reference.........0.800V...............: v
MCH/DRAM Ref..........0.900V...............: v
ICH I/O...............1.550V...............: v
ICH Core............……1.100V...............: v
[b]DRAM[/b]
DRAM Voltage..........1.800V...............: v
DRAM Termination......0.900V...............: v
Channel A Reference...0.900V...............: v
Channel B Reference...0.900V...............: v
[b]{U]Advanced Settings[b]{U]
Limit CPUID Max. to 3......................: [Disabled]
No-Execute Memory Protect..................: [Disabled]
CPU Enhanced Halt (C1E)....................: [Disabled]
C2/C2E State Support.......................: [Disabled]
x C4/C4E State Support.....................: [Disabled]
CPU Thermal Monitor 2(TM2) ................: [Enabled]
CPU EIST Function..........................: [Disabled]
Virtualization Technology..................: [Disabled]
