- Nov 10, 2004
- Detroit
n/m. This product doesn't come up in Outpost's search anymore, but the OP's link still works.
VinnyTAMU said:I would think that a 300watt plus PSU should do fine. I am going to use my Fortron/Sparkle 350w PSU for this mobo/psu and FX5500, 250gb SATA drive, DVD burner combo.
iceage said:Great! I have a FSP 350 just sitting around with nothing to do.
MB/CPU got here today. The chip I got is definately the 130nm CG stepping. Fond hope dashed too quick.
I'll probably set this up this weekend. Hopefully this low wattage CPU won't require me to sink the fets on this ECS board. I'm out.
I wouldn't sweat it too much. ECS makes boards across the spectrum like many others, from garbage (pcchips) to some Abits (decent/good) to their own high end editions (decent/good).Beginner said:i only clocked them to 210htt. i should have gotten more aggressive but i was deterred because of all the negative comments/reviews i read here about ecs gear.
Ya, they all do. There are now people at other forums claiming to have installed Win XP64 beta on this combo. I ought to find my copy of XP64 and lay this issue to rest, the problem is i hate the setup process, and don't want to use some buggy OS, and then have to install regular winxp all over again.VinnyTAMU said:Also the sticker on the OEM processor says "32-bit"
sJetski said:I wouldn't sweat it too much. ECS makes boards across the spectrum like many others, from garbage (pcchips) to some Abits (decent/good) to their own high end editions (decent/good).
Up the voltage a notch, lower the HTT multiplier a notch, adjust the ram divider, and let her rip
Trying not to get my hopes up, but people in other forums keep insisting that they're 64bit (?) No biggie either way i guess.
VinnyTAMU said:Well, just got mine in the mail and I selected Gound Shipping!
Anyways the model # I got was SDA3100AIP3AX
Stepping : CBAEW 0524CPDW
I would like to start a thread for these combos to post overclocking results.
beavismorpheus said:So the only real difference between the palmero and newcastle cores is that the palermo has 256 and 128 cache?
I was always disgusted when i heard the word sempron. I always thought it was this uber crippled, avoid at all costs processor, but it doesnt seem so bad anymore.
Im thinking this for the ultimate budget rig.
this mobo and cpu = 90
1 gig pc3200 = 40 (MIR)
Forton PSU= 40
7800gs= 270 (MIR)
spare case, spare hdd, cd
So thats about $450 for the whole rig. pretty darn cheap and i bet it would perform similar to my s939 rig. LoL
I would guess it could score maybe 7000 '05 3d marks What do you think?
It varies with the newcastle cores, this combo's 3100+ has 256 KB L2 cache, and more are coming out of the wordwork claiming that X64bit instuctions are left enabled. Another fellow over at the [H] forums did me a favor by testing out Win XP64 beta and he says it runs fine with the exception of some incompatible video mode, it otherwise runs fine he says.douglasb said:The Newcastle-based Semprons don't have SSE3 or AMD64, and only have 128 KB L2 cache, so they are more crippled.
Do so please! a little more confirmation never hurt, lolmoz_21 said:I'll try installing 64bit Xp on it. I've got the trial cd from back when they had it up for downloading. I'll let everyone know later. My chips are the same stepping as above, btw.
sJetski said:Do so please! a little more confirmation never hurt, lol
if not 64 bit enable you get stuck at setup screen ( the blue) and it say not 64 bit cpu i think. i did it went i change 64 bit to 32 bit and hope to reinstall like that [/QUOTE]moz_21 said:loaded up the XP64bit cd. It booted fine and installed up to the point where it asks for the CDkey, which it turns out I recieved in an Email a long time ago and have since lost... Does that seem like proof enough that they are 64bit enabled? I never actually got into Windows, but I don't know if you can install XP64bit on a 32bit cpu either.
Banyan said:i dont think installing xp64 means much as it is capable of running 32bit
Don't even consider it.beavismorpheus said:is it ok to test the cpu without a heatsink? I want to test it for now to see if it works. im thinking of blowing some air on it with a portable fan just long enough to see if the system posts. only a few seconds. i dont want to install a heat sink just to see if i need to request an RMA. the one guy said his motherboard was DOA so now i want to test.
yesSpeedPrez said:Anyone know if the stock heatsink from a s939 FX55 will be compatible? Thanks for the help!
moz_21 said:Yeah I wasn't sure if the setup portion was actually 64bit, but it didn't lock up or anything, I just don't have the email with the key to continue further installation.
Anyhow, an update. I loaded plain ol' XP on it and ran CPUZ, it shows 256KB of cache and AMD-64 instructions, Paris core.
