- May 10, 2009
(Please note this is a work in progress and may change somewhat, don't let this discourage you! Anything you submit will stay listed, it may just move slightly)
This thread is for all to submit their SuperPi 32M Scores for a Categorized Top List. All OCForum members have a chance to be listed here! This is not exclusive to OCF Benching team people. While this is a nice and friendly intraforum competition thread, this thread is also useful as a reference for what your score should and can achieve with this benchmark.
If you are unfamiliar with SuperPi 32m, please click here and read this page.
To download the proper version of SuperPi, click here.
READ THESE INSTRUCTIONS BEFORE POSTING!
1) You must use this version of superpi: Link
2) Run the 32M test.
3) Take a screenshot of the finished superPi run and CPUz memory and main tabs.
Your screenshot should look like this:
4) Post the screenshot in this thread, either as an attachment or hosted elsewhere.
5) Alternatively, a link to a HWBot submission works fine too.
6) Done!
The following format is mandatory:
Copy and paste this into your post, and input your own name/specs: [noparse][*][b]USER[/b] - [URL="http://link-to-screenshot-or-HWBot-score-goes-here"]SCORE[/URL] - CPU @ CPU SPEED - MEMORY SPEED/TIMINGS, COOLING (AIR,H2O, DRY ICE, LN2, ETC.)[/noparse]
Example (this is what your post should look like): [*][b]I.M.O.G.[/b] - [URL=http://hwbot.org/community/submission/2124168_i.m.o.g._wprime_32m_phenom_ii_x6_1090t_be_ 4sec_156ms]4.156[/URL] - 1090T @ 5981 - Gskill Trident @ 780/7-7-7-15-20-1T (LN2)
[*b]Bobnova[/b] - [*URL="http://bobnova.com/ocforums/pi32m-14m-16.411.jpg"]14m 16.411[*/URL] - e5200 @ 3625Mhz - DDR2@432-5-5-5-15 (Air)
You can copy either example and paste your info in it!
(Leave asterisks in place until I have your score posted, then edit your post if you want to.)
You may also leave the link at it's default and attach your screenshot to your post.
If you would like to see the scores of the benchmarking team, you can see those HERE (Thanks Voidn!!!). A lot of these guys run extreme cooling and have a lot of tricks and tweaks up their sleeves to reach those scores. If you are interested in joining the benchmarking team and raising your scores, please CLICK ME. In here once you completed your 10 benchmarks and joined OCF at Hwbot, you will gain access to the benching lounge and get to share and learn some of the secrets of our team! You will not find a better group of guys to learn and share tricks and tweaks with!
Overall Top Guns AMD (regardless of CPU type, best score per person):
Overall Top Guns Intel (regardless of CPU type, best score per person):
AMD:
Phenom II:
Athlon64/Sempron (AM2/AM2+):
Socket 939:
Socket 754:
Intel
SandyBridge (LGA1155):
Core i7 (X58-1366):
Core i7 and i5 750/760 (P55/H55-1156):
Core i5 (dual core):
Core i3:
Core2 Duo(45nm):
Core2 Duo(65nm, e6xxx):
65nm Other (65nm, e4xxx, e2xxx, e1xxx, NOT P4 based!):
Pentium 4 based CPUs:
6) Done!
- I.M.O.G. - 10m 55.594s - X4 965BE @ 6618Mhz - 826/7-7-7-15, LN2
- miahallen - 11m 29.109s - X6 1090T @ 6247 - DDR3-1893/7-7-7-20 1T, COOLING LN2
- xsuperbgx - 12m 27.593s - 955BE @ 6048 - Gskill Trident @ 746/7-7-6-15, (LN2)
- xokeman - 14m 15.140 - 1090t @ 5060 - DDR3@733-7-7-7-23-34-1t (Dice)
- xXSebaSXx - 14m 54.722 - AMD 720BE (3 Cores Active) @ 4625MHz - DDR3 @ 833/7-8-7, DICE
- ChanceCoats123 - 15m 47.922 sec - Phenom II 720 @ 4504 - DDR3 1412 @ 6-5-6-20-24 1T, DIce
- Efonzerellie - 16m 9.050s - 955BE @ 4275Mhz- [email protected] 8-9-8-25(Air)
- saint19 - 16m 35s 801ms - X6 1090T @ 4219.40Mhz - DDR3@1600-8-8-8-21 (H2O)
- A-Dub - 16m 44.205s PhII 965@4218 ddr3@669-7-7-7-24 (Unknown, assume water)
- Dooms101 - 16m 47.887s - AMD PhII 965BE @ 4.368 - DDR3-1664 (9-9-9-28), Air
- Prunecandy - 17m 14.000s - Phenom II @4107ghz - DDR3-707@8-8-8-23-27-1T.(air)
- CgS Drone - 17m 38.204 - 955BE@4000mhz - DDR3@800-9-9-9-28. (Stock air)
- Dr. McCoy - 23m 57.625s - A64 Opteron 175 @ 3190MHz / 1024MB DDR @ 227MHz: CL2 2-2-6 1T / H2O
- QuietIce - 28m 15.203 - Athlon64@2910mhz - DDR-265@3-4-4-8-16-1T. (water)
- Kowalski3500 - 31min 13.235 - Opteron 165 @ 2457 - 223mhz/3-4-4-8, Air
- Bobnova - 56m 24.313 - Athlon64@1603mhz - [email protected]. (Stock air)
- miahallen - 6m 7.844s - I7 980X @ 6205 - DDR3-1880/7-7-6-18 1T, COOLING LN2
- PolRoger - 6m 13.402s - i5 2500K @ 5582.5MHz - Gskill Trident DDR3@ 1083.1MHz/9-9-9-24-1T, (Air)
- discman - 6m 30.641 - i5 2500K @ 5348.6Mhz - DDR3@1080 9,10,9,27 1T Air
- dejo - 6m 50.110s - I7 920 @ 5270 - DDR3-2008/8-8-8-18, COOLING Dry Ice
- Bobnova - 6m 54.750s i7 980x@5363 ddr3@812-7-7-7-18 (dry ice)
- DaveHCYJ - 6m 58.954 - i5 2500K @ 5127Mhz - DDR3@804mhz 7-8-7-24. (Air)
- SamSaveMax - 7m 36.222 - i7 [email protected] - DDR3@910MHz 7-9-8-20 60-1T (AIR)
- Woomack - 7min 45.250 - i7 920 @ 4660 MHz - DDR3-1774@7-6-6-18 1T ( H2O)
- onefstsnake - 7m 52.481s i7 920@4803 ddr3@915-9-9-9-24 (unknown cooling)
- xoke - 7m 54.711s - i7 920 @ 4893ghz - DDr3 932-7-9-7-24-102-1t (DRY ICE)
- spiritedandy - 8min_16sec_393ms - 980X@4833mhz - DDR3@1870Mhz 7-8-7-20 1T(H70 corsair)
- Brutal-Force - 8m 25.535s - i7 860 @ 4716mhz - DDr3 943mhz 7-7-7-20 (AIR?)
- bda1967 - 8m 55.931s - i7 920 @ 4200MHz - DDR3@800 9-9-9-24 (AIR)
- redduc900 - 8m 59.859 - i7-860@4140Mhz - DDR3-2400@1242MHz 9-11-9-28 (Air)
- Noshei - 9m 4.764s - i7 930 @ 4200Mhz - DDR3@800mhz 7-8-7-24. (H20)
- Georanma - 9m 35.220s - i3 530 @ 4.3674 GHZ - DDR3 595MHz/6-6-6-15, Air
- theELVISCERATOR - 11m 18.843s - e8600 @ 4500 - Corsair Dominator @ 540/5-5-5-15 1T (air)
- xXSebaSXx - 13' 14" 531ms - E6300 @ 3842Mhz - DDR2@549mhz 5-5-5-15-42-1T (DICE)
- Lucky23 - 13m 39.844s - E8500 @ 4227, DDR2-445-8-8-8-18 AIR
- Badbonji - 15m 7.048s - P9500 @ 3133 - DDR2 494.8MHz @ 5-5-5-15, Stock
AMD:
Phenom II:
- I.M.O.G. - 11m 28.463s - 965BE @ 6367 - Gskill Trident @ 786/7-7-7-15, (LN2)
- I.M.O.G. - 11m 50.332s - X6 1090T @ 6130Mhz - 870/8-8-8-20, LN2
- I.M.O.G. - 14m 39.873s - X6 1090T @ 4698Mhz - 850/7-7-7-20, AIR (rig outside, .5C)
- ChanceCoats123 - 17m 35.937s - Phenom II x3 720 @ 3894Mhz - DDR3 @ 630 6-6-6-20-30 (Air)
- CgS Drone - 18m 20.078s - 955BE @ 3799.9 - DDR3 1333/7-7-7-24 1T, Air
- bda1967 - 18m 39.505s - Athlon II X4 @ 3711.8MHz - DDR3-1600@683 7-7-7-20 (AIR)
Socket 939:
Socket 754:
- Dr. McCoy - 26m 22.078s - Athlon64 3700+ - DDR@250mhz 2-3-3-6 AIR
Intel
- PolRoger - 6m 33.355s - i7 2500K @ 5504mhz DDR3@ 800-6-8-6-24 (AIR)
Core i7 (X58-1366):
- miahallen - 6m 57.300s - Xeon W3580 @ 5322 - DDR3-2202/8-8-8-20 1T, COOLING LN2
- SamSaveMax - 7m 40.045 - i7 930 @ 4720.8Mhz - DDR3-1798@8-9-6-20 (Air)
- miahallen - 7m 8.830s - I5 750 @ 5195 - DDR3-1980/7-7-6-18 1T, (LN2)
- SamSaveMax - 8m 3.320s - i5 750 @ 4752.2Mhz - DDR3 @ 990MHz/8-9-8-20 1T (AIR)
- miahallen - 6m 26.593s - I5 670 @ 6441 - DDR3-1832/7-7-7-20 2T, COOLING LN2
- dejo - 7m 34.141s - I5 661 @ 5508 - DDR3-2040/7-9-7-18, COOLING Dry Ice
- SamSaveMax - 8m 31.140s - i5 650 @ 4975.5Mhz - DDR3 @ 995MHz/9-10-9-24 2T (AIR)
Core i3:
- SamSaveMax - 8m 11.042s - i3 540 @ 5152.7Mhz - DDR3 @ 896MHz/9-9-8-22 2T (AIR)
- Woomack - 8min 37.765 - i3 540 @ 4922 MHz - DDR3-1712@8-7-7-21 1T ( H2O)
Core2 Duo(45nm):
- SamSaveMax - 10m 44.714s - E8400 @ 4680.2Mhz - DDR2 @ 520MHz/5-5-5-15 2T (AIR)
- Badbonji - 13' 14" 531ms - E6300 @ 3842Mhz - DDR2@549mhz 5-5-5-15-42-1T (DICE)
- Bobnova - 14m 16.411 - e5200 @ 3625Mhz - DDR2@432-5-5-5-15 (Air)
- Woomack - 17min 0.536 - Core 2 T6600 @ 2795 MHz - DDR2-1010@6-6-6-15 ( stock air )
