- May 10, 2009
(Please note this is a work in progress and may change somewhat, don't let this discourage you! Anything you submit will stay listed, it may just move slightly)
This thread is for all to submit their WPrime 32m scores for a Categorized Top List. Scores for a Categorized Top List. All OCForum members have a chance to be listed here! This is not exclusive to OCF Benching team people. While this is a nice and friendly intraforum competition thread, this thread is also useful as a reference for what your score should and can achieve with this benchmark.
If you are unfamiliar with WPrime 32m, please click here and read this page.[/B]
To download the proper version of WPrime, click here.
READ THESE INSTRUCTIONS BEFORE POSTING!
1) You must use this version of WPrime: Link
2) Run the 32M test.
3) Take a screenshot of the finished WPrime run and CPUz memory and main tabs.
Your screenshot should look like this:
4) Post the screenshot in this thread, either as an attachment or hosted elsewhere.
5) Alternatively, a link to a HWBot submission works fine too.
6) Done!
The following format is preferred, but not necessary:
Copy and paste this into your post, and input your own name/specs: [noparse][*][b]USER[/b] - [URL="http://link-to-screenshot-or-HWBot-score-goes-here"]SCORE[/URL] - CPU @ CPU SPEED - MEMORY SPEED/TIMINGS, COOLING (AIR,H2O, DRY ICE, LN2, ETC.)[/noparse]
Example (this is what your post should look like): [*][b]I.M.O.G.[/b] - [URL=http://hwbot.org/community/submission/2124168_i.m.o.g._wprime_32m_phenom_ii_x6_1090t_be_ 4sec_156ms]4.156[/URL] - 1090T @ 5981 - Gskill Trident @ 780/7-7-7-15-20-1T (LN2)
If you would like to see the scores of the benchmarking team, you can see those HERE (Thanks Voidn!!!). A lot of these guys run extreme cooling and have a lot of tricks and tweaks up their sleeves to reach those scores. If you are interested in joining the benchmarking team and raising your scores, please CLICK ME. In here once you completed your 10 benchmarks and joined OCF at Hwbot, you will gain access to the benching lounge and get to share and learn some of the secrets of our team! You will not find a better group of guys to learn and share tricks and tweaks with!
Overall Top Guns (regardless of CPU type, best score per person):
AMD:
One core:
Two cores:
Three cores:
Four cores:
Six cores:
Intel
One core (without HT):
One core (with HT):
Two cores (without HT):
Two cores (with HT):
Four cores (without HT):
Four cores (with HT):
Six cores (with HT):
Eight cores (with HT):
6) Done!
- miahallen - 2.718 - i7 980X @ 5908MHz - DDR3-1790 7-7-6-18 1T, LN2
- spiritedandy - 2.774 -980x@ 6055.7Mhz - DDR3@ 1252mhz 6-6-6-17 1T (Cascade)
- Voidn - 2.844 - 980x@ 5.680 - HyperX @ 887 8-8-8-24, LN2
- Bobnova - 3.062s - i7 980x@5250 ddr3@772-8-7-7-18 (Dry Ice)
- nzaneb - 3.604 -i7 980X @ 4591.9mhz - DDR3@ 798.1mhz 7-7-7-20, (Measly Air, subzero to come)
- Dolk - 4.078 - Phenom II 1090T @ 6,067.8 - 1587 8-9-8-24-31, LN2
- I.M.O.G. - 4.156 - 1090T @ 5981 - Gskill Trident @ 780/7-7-7-15-20-1T (LN2)
- SamSaveMax - 4.546 - i7 2600K @ 5322.9MHz - DDR3 @ 1071MHz 8-10-9 27 1T (AIR)
- dejo - 4.547 - i7 920@5271mhz DDR3@1004mhz 9-9-9-24 (Dry Ice)
- PolRoger - 4.647 - i7-2600K @ 5403.5Mhz - DDR3 @ 800mhz 6-8-6-24 1T (Air)
- hokiealumnus - 4.679 - i7 2600K @ 5447 Mhz - DDR3@2133mhz 9-11-9-28. (Water)
- wint0nic - 4.680 - i7 980X @ 4013 Mhz - DDR3@1606 9-9-9-24. (Water)
- xokeman - 4.914 - 1090t @ 5236 Ram @ 1396 9-9-9-24-33 (DRY ICE)
- Earthdog - 5.07 - i7 860 @ 4840Mhz - DDR3@ 1100mhz 9-9-9-24. (Dry Ice)
- xokeman - 5.078 - 1090t@5176 (Dry Ice)
- SamSaveMax - 5.203 - i7 930 @ 4595.1MHz - DDR3 @ 875MHz 7-8-7 22 1T (AIR)
- GoD_tattoo - 5.288 - i7-860 @ 4811mhz - ddr3 687mhz/8-8-8-24, DRY ICE
- Woomack - 5.522 - i7 920 @ 4468MHz - DDR3 1600@851MHz/7-6-6-19 1T, ( H2O )
- discman - 5.865 - i5 2500k @ 5316.6Mhz - DDR3 @ 919MHz 9,9,9,24 1T Air
- Hilight5.866 - 1090t @ 4389 Ram @ 1003 7-9-7-24 (air)
- jevery - 5.898 - i7-950 @ 4300 - Dominator @ 1495/7-7-7-20, (AIR)
- lolwut - 5.993 - i7 920 @ 4200mhz - DDR3@1002mhz 8-9-8-24 (H20)
- xsuperbgx - 6.032 - AMD 955BE@6032 - DDR3@693mhz 7-8-7-24-1T. (LN2)
- Pvt.Dancer - 6.123 - PhII 1090t@4307mhz DDR3@792mhz 9-9-9-24
- Troy - 6.231s - Core i7@4312mhz ddr3@784-9-9-9-24
- bda1967 - 6.333 - i7 920 @ 4000Mhz - DDR3@800mhz 9-9-9-24. (AIR)
- redduc900 - 6.346 - i7 860 @ 4103.1MHz - DDR3@1296MHz 9-11-9-28. (AIR)
- DR650SE - 6.599 - i7 920XM @ 3787.7.9Mhz - DDR3 @ 728MHz/9-9-9-21 (Stock)
- ChanceCoats123 - 6.906 - PII 555 x4 @ 5300Mhz - DDR3 @ 707MHz/6-6-6-20-24 1T (DIce)
- xXSebaSXx - 7.156 AMD PII 555BE (x4) @ 5031Mhz - DDR3@688mhz 8-8-8-20-27-1T. (Dry Ice)
- CgS Drone - 8.64 - 955BE @ 4182Mhz - DDR3@656mhz 7-7-7-24. (Air)
- Dr. McCoy8.845 - PhII 555 BE (Unlocked to 4x cores) @ 4347MHz / DDR3 @ 626MHz: 8-7-7-20 2T / H2O
- OptyTrooper - 21.609 - Athlon X2 5000 @ 3365.5/2048MB DDR2 @ 306Mhz 5-3-3-9 2T
- cold.nut - 22.494s - Athlon 64 6000+ X2 @ 3885MHz - DDR2 856MHz @ 4-4-4-7-17 2T (Dry Ice)
- Old H-Ware Tech - 8.031 - PhII 955 @ 4600, DDR3 @ 666-9-9-9-24
- Georanma - 28.829s - i3 530 @ 4.3674 GHZ - ddr3@595/6-6-6-15, Air
- Noshei - 29.396s - Mobile Core 2 Duo T9550 @ 2.66GHz - DDR3 @531.8MHz 7-7-7-20
AMD:
One core:
- xsuperbgx - 27.610 - AMD Sempron 140 @ 5366 - corsair ddr2 @394 4-3-3-9 (LN2)
- Dr. McCoy - 48.656s 4000+ San Diego @ 3278MHz / 1024MB DDR @ 234MHz: 2.5-3-3-6 / H2O
Two cores:
- CgS Drone - 22.828 - Athlon 6000+ @ 3761Mhz - [email protected] 5-5-5-15 1T (Dry Ice)
- Dr. McCoy - 24.484 - Opteron 175 @ 3245mhz [email protected] (H2O)
- Dr. McCoy - 31.453 - (2) AMD XP-M 2800 @ 2609MHz / 1024MB DDR @ 163MHz: 2-2-2-6 / Air
Three cores:
Four cores:
- I.M.O.G. - 5.734 - 965BE @ 6346 - Gskill Trident @ 846/7-7-7-15-20-1T (LN2)
- xsuperbgx - 7.254 - AMD 955BE@5042 - DDR3@700mhz 9-9-9-24. (Dry Ice)
- xXSebaSXx - 7.875s - 955BE @ 4579Mhz - DDR3 @ 803MHz/8-9-8-21 1T (AIR)
- CgS Drone - 8.656 - 955BE @ 4180Mhz - DDR3@587mhz 7-7-7-24. (Air)
- CgS Drone - 8.734 - 955BE @ 4142.2Mhz - [email protected] 7-7-7-24. (Air)
- xXSebaSXx - 8.750 - AMD 555BE (4x) @ 4124.7Mhz - DDR3@833mhz 7-8-7-24-21-1T. (Air)
- CgS Drone - 8.812 - 955BE @ 4104Mhz - DDR3@720mhz 7-7-7-24. (Air)
- Dr. McCoy - 8.845 - PhII 555 BE (Unlocked to 4x cores) @ 4347MHz / DDR3 @ 626MHz: 8-7-7-20 2T / H2O
- Dolk - 9.219 - Phenom II 940@3900 (H20)
- bda1967 - 11.136 - Athlon II X4 635 @ 3711.8Mhz - DDR3-1600@683mhz 7-7-7-20. (AIR)
Six cores:
- miahallen - 4.25 - X6 1090T @ 5875MHz - DDR3-1666 9-9-9 24 1T, LN2
- I.M.O.G. - 5.328 - 1090T @ 4567 - DDR3@870mhz 7-7-7-15 (Winter Air)
- Hilight 5.866 - 1090t @ 4389 Ram @ 1003 7-9-7-24 (air)
Intel
- Bobnova - 47.765 - Celeron 420 @ 3419mhz, D9 DDR2 @ 425mhz 3-3-3-4 (DICE)
One core (with HT):
- xXSebaSXx - 65.390 - P4 630 @ 4270MHz - DDR2 @ 474MHz 5-5-5 15 42 2T (AIR)
- xXSebaSXx - 21.109 - E6300 @ 3920 - OCZ Reapers @ 560/5-5-5-5-15-42-2T (DICE)
- miahallen - 8.094 - i5 670 @ 5957MHz - DDR3-1375 6-6-6 18 1T, LN2
- Bobnova - 8.342 - i3 540 @ 5693Mhz - DDR3@742mhz 7-7-7-18. (Dry Ice)
- GoD_tattoo - 9sec 547ms - Core i3-530 @ 5170mhz - DDR3 @705MHz 9-9-9-22 Dry Ice
- SamSaveMax - 9.765 - i5 650 @ 4875.9Mhz - DDR3 @ 975MHz/9-10-9-24 2T (AIR)
- Woomack - 9.796 - i3 540 @ 4969MHz - DDR3 1600@864MHz/7-6-6-18 1T, ( H2O )
- SamSaveMax - 9.953 - i3 540 @ 4796.7Mhz - DDR3 @ 872MHz/8-9-8-22 1T (AIR)
- miahallen - 5.89 - i5 750 @ 5174MHz - DDR3-1971 7-7-6 18 1T, LN2
- SamSaveMax - 6.374 - i5 750 @ 4761MHz - DDR3 @ 906MHz 9-9-9 28 1T (AIR)
- Earthdog - 7.828 - Q9650 @ 4873Mhz - DDR3@ 541mhz 5-5-5-15. (H20)
- miahallen - 8.69 - Core 2 Q6600 @ 4744MHz - DDR3-1686 7-6-5 16 1T, DICE
- miahallen - 4.093 - Xeon X5677 @ 5818MHz - DDR3-2144 7-8-7-20 1T, LN2
- nzaneb - 4.903 -i7 920 @ 4948mhz - DDR3@ 941.6mhz 7-7-7-21, (DRY ICE)
- SamSaveMax - 5.281 - i7 930 @ 4552.3Mhz - DDR3 @ 867MHz/7-9-7-22 1T (AIR)
- SamSaveMax - 5.344s - i7 930 @ 4510.5Mhz - DDR3 @ 859MHz/8-9-7-22 1T (AIR)
- Troy - 6.231s - Core i7 930 @4312mhz ddr3@784-9-9-9-24
- spiritedandy - 3.494 -980x@ 4960Mhz - DDR3@1920mhz 7-8-7-20 1T (H70 corsair)
