- Dec 12, 2005
Ok, basically, heres the deal...this is driving me crazy, and I really dont know what else to do to fix this issue
I've got 3 harddrives... 2 are SATA, and 1 is on IDE slaved(DVD is master)
I installed xp on 1 of the sata drives, but I don't leave the IDE HD plugged in all the time as it's mainly for backup of data, and aside from that it's old and LOUD, so I like to unplug the power 90% of the time.
So, here's the weird part. If it's not plugged in, windows takes about 3-4 times longer to boot. The moment I have it plugged it, and boot up...bam windows is loading very noticeably faster. I've tested this quite a few times, and it's not just a fluke thing.
I've tried disabling as many startup items as possible and services disabled and still no luck.
It's as though windows is waiting to find the other drive, times out, and then continues booting. For IE - with the IDE drive in, my HDD light is on the entire time and I get right into windows, but when I take the drive out(which is most of the time), the light will be off for quite some time, ,and then startup again after awhile, then I'm in windows.
So, any alternatives besides always leaving the HD always plugged in or buying a new HD thats quieter ?
