- Jul 9, 2002
- Sotira, Cyprus
Hi peeps,
Have never owned an Intel CPU so need some help deciding if a certain CPU will fit on a certain mthbrd.
My Uncle wants to upgrade his computer, he has a ECS (Elitegroup) P6BAT-A+ mthbrd, the mthbrd supports 133mhz Socket 370 CPU's. On the ECS website there is conflicting information.
I found a webpage Pentium III CPU Support List which lists ECS mthbrds that support PIII processors. The P6BAT-A+ (rev 2.x, mine is a rev 2.0) supports FC-PGA
(133MHz) PIII's, but no info on the speed of CPU.
The specification webpage of P6BAT-A+ (P6BAT-A+ Specs says different), to quote
Processors
* SECC2 Pentium III up to 850MHz(100MHz FSB), Pentium II
* Celeron PPGA up to 533MHz
Im looking on eBay to buy the right CPU, will I be ok going for a 133mhz PIII up to 1000mhz?
Another thing,
the RAM my uncle has is
2 x PC100
1 x PC133
There are options in the bios to run the ram at variating frequencies (at the moment with 66fsb CPU the options are 66/75/83). There is a jumper on the mthbrd to force it to 100mhz, i believe with the right CPU the options increase to 100/133.
Hope someone can provide me with some help
mong
Processors
Another thing,
2 x PC100
1 x PC133
mong
