*EDIT
Inline Cooling System for my Chieftec Dragon case.(w/o window)
Water Block: MAZE3
3"H x 2.125"W x 7/8"D
AMD Processor Copper Top
1/2' Fittings Polypropylene
Water Pump: Ehiem 1250
110/120V - 317GPH
Radiator: Chevette Pro Core
1/2" Barbs
6" H x 7"H x 2"T
Tubing: 1/2" High Grade Tygon Tubinf
1/2"D x 3/32" Wall
I will most likely be using 120mm front fan, 120mm(86.5 cfm, 35.5dB) top fan, 80mm(76cfm) (2) rear fan & 92mm(?) side panel fan.
Most likely only going to start with CPU Water Cooling but will eventually extend to GPU as well.
Water Block: MAZE3
110/120V - 317GPH
1/2" Barbs
6" H x 7"H x 2"T
1/2"D x 3/32" Wall
