- Mar 8, 2007
- My Northbridge, Toronto
Okay, so I'm not an expert on overclocking GPU's but I've read the FAQs and I thought I'd give it a try and I also decided to post my method as well as results. Now during this I have noticed some odd trends with overall stability and temperature fluctuations, hopefully one of the guru's on this site can take a look and give me advice on how I might get a better overclock as well as try and make heads or tails on my findings. So here we go....
Test 1
Obviously I went stock to run the first test to get a base 3DMark score as well as observe temperature trends.
Core Clock - 824MHz
Memory Clock - 900MHz
Fan Cycle - 25%
Temp (Peak) - 90c
3DMark06 - 11778
Test 2
Time to up the core clock a bit.
Core Clock - 844MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - 11769
Already noticed a strange occurrence, my temps went down 10c and my score actually went down a few points!? So back to default for another run, lets see what happens.
Test 3
Core Clock - 824MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - 11779
Seems to be an anomaly, lets move on.
Test 4
Lets up the clock a little more...
Core Clock - 857MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - 11713
Now this trend is alarming, my clock goes up but my score is going down!?
Test 5
Let's up both clocks and see what happens...
Core Clock - 891MHz
Memory Clock - 990MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - 11917
That's better! my score has gone up a few hundos.
Test 6
Okay now lets up those clocks some more...
Core Clock - 918MHz
Memory Clock - 1020MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - N/A
CRASHED! We have our first sign of instability, maybe the memory clock was raised to high? Let's see if that's the case.
Test 7
Core Clock - 918MHz
Memory Clock - 1008MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - N/A
CRASHED! Hmm, perhaps it's the core clock??
Test 8
Let's lower the core clock a bit and testy testy.
Core Clock - 905MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - 12188
There we go! hehe, that's what I'm talking about. However, this can't be the 3870x2's limits!?!? I won't believe that, time to start seeing if temps are the issue.
Test 9
Okay, let's up the core, lower the memory and up the fan cycle to 50%.
Core Clock - 932MHz
Memory Clock - 999MHz
Fan Cycle - 50%
Temp (Peak) - 79c
3DMark06 - 12195
Better, but the temps only changed 1c, yet everything seemed stable.
Test 10
Up goes the clocks...
Core Clock - 945MHz
Memory Clock - 1080MHz
Fan Cycle - 50%
Temp (Peak) - 79c
3DMark06 - N/A
CRASHED! I really think this could be a temp issue, let's up that fan cycle to 75%...
Test 11
Core Clock - 945MHz
Fan Cycle - 75%
Temp (Peak) - 79c
3DMark06 - 12208
Our highest score yet!!! But, I'm not liking the fact the temp hasn't changed in the NV Monitor?? Really odd. But since it seems stable let's go ahead and raise core clock a smidge.
Test 12
Core Clock - 959MHz
Fan Cycle - 75%
Temp (Peak) - 50c
3DMark06 - N/A
CRASHED! Okay wtf! lol The temps dropped this time but we have instability?? You know what, it's time for a little suicide experiment hehe....
Test 13
Crank that core up baby! Also upping the fan cycle to 100%!
Core Clock - 972MHz
Fan Cycle - 100%
Temp (Peak) - 48c
3DMark06 - N/A
CRASHED! Okay, somethings really fubar here. I think it's time for a restart maybe.
~~~RESTARTED~~~
Fan cycle to 80% just curious...
Test 14
Core Clock - 972MHz
Fan Cycle - 80%
Temp (Peak) - 50c
3DMark06 - N/A
CRASHED! I thought so, but I had to be sure.
~~~RESTART~~~
Test 15
So it could be the clock?? Let's try lowering the core a bit but keep the fan cycle at 50%
Core Clock - 945MHz
Fan Cycle - 50%
Temp (Peak) - 55c
3DMark06 - 11796
So we seem to be a little more stable now.
Test 16
Let's up that core once again..
Core Clock - 959MHz
Fan Cycle - 50%
Temp (Peak) - 50c
3DMark06 - N/A
CRASHED! This is getting annoying. I decided at this point to try to see if I'd get different results using CCC, loaded it up and POW! CRASH, reboot, but after the bios screen all I got was MAME ROM loading liek screens!!! Oh frack! Maybe a killed my card!?!? Not going to panic yet, unplugged the PSU, waited a few minutes and tried the reboot...
Everything seems fine, must have been the temps. Time to try a different approach.
Test 17
Let's try this, core up, memory default..
Core Clock - 972MHz
Fan Cycle - 80%
Temp (Peak) - 59c
3DMark06 - 11918
Needless to say, I need to play around with this a lot more, I'll skip ahead and show you the final result;
Test 81
Core Clock - 972MHz
Fan Cycle - 70%
Temp (Peak) - 55c
3DMark06 - 12280 <---- HIGHEST SCORE!
I obviously tried soooo many different combinations, but his is the only "stable" overclock I could achieve. Is there anything else anyone would suggest I try?? I cannot believe that 990MHz is the highest the memory can go!?!? The core I can believe at 972MHz, that's a fairly good overclock with stock cooling I would think. In any event, let me know what you think. Thanks for reading.
Test 1
Core Clock - 824MHz
Fan Cycle - 25%
Temp (Peak) - 90c
3DMark06 - 11778
Test 2
Core Clock - 844MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - 11769
Test 3
Core Clock - 824MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - 11779
Test 4
Core Clock - 857MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - 11713
Test 5
Core Clock - 891MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - 11917
Test 6
Core Clock - 918MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - N/A
Test 7
Core Clock - 918MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - N/A
Test 8
Core Clock - 905MHz
Fan Cycle - 25%
Temp (Peak) - 80c
3DMark06 - 12188
Test 9
Core Clock - 932MHz
Fan Cycle - 50%
Temp (Peak) - 79c
3DMark06 - 12195
Test 10
Core Clock - 945MHz
Fan Cycle - 50%
Temp (Peak) - 79c
3DMark06 - N/A
Test 11
Core Clock - 945MHz
Fan Cycle - 75%
Temp (Peak) - 79c
3DMark06 - 12208
Test 12
Core Clock - 959MHz
Fan Cycle - 75%
Temp (Peak) - 50c
3DMark06 - N/A
Test 13
Core Clock - 972MHz
Fan Cycle - 100%
Temp (Peak) - 48c
3DMark06 - N/A
~~~RESTARTED~~~
Test 14
Core Clock - 972MHz
Fan Cycle - 80%
Temp (Peak) - 50c
3DMark06 - N/A
~~~RESTART~~~
Test 15
Core Clock - 945MHz
Fan Cycle - 50%
Temp (Peak) - 55c
3DMark06 - 11796
Test 16
Core Clock - 959MHz
Fan Cycle - 50%
Temp (Peak) - 50c
3DMark06 - N/A
Test 17
Core Clock - 972MHz
Fan Cycle - 80%
Temp (Peak) - 59c
3DMark06 - 11918
Test 81
Core Clock - 972MHz
Fan Cycle - 70%
Temp (Peak) - 55c
