Last night I was able to get a little bit of time to play with some settings to actually work on getting a stable 4ghz overclock. Before calling it a night, I was up to 1.37v on the CPU but crashed after about 11 minutes under OCCT (267x15). I had one failure on core 1 with the next step under in regards to voltage and a failure on core 2 at 1.37. Probably wont mess with it again until the weekend but it looks promissing for getting a stable 4ghz thus far. Max temp was 49.2c in OCCT. I'll throw some more voltage at it and then move on to the memory. CPU-NB is at 1.15v and RAM is at 1.5.
Systems specs as it sits:
Cooler Master 840
MSI 890FXA GD70 (1.7 bios)
X6 1075t with a CoolerMaster 212+
G.Skill Eco 4x2gb
EVGA GTX 470 with a Zalman VF3000 (huge decrease in temps!)
A-Data S599 (3.4.6 firmware cleared up my issues)
3tb WD Caviar Green
Antec TPQ-850 PS
I just ordered a Gigabyte 6950; the temptation to unlock to 6970 and run Crossfire was just to much to pass up. For the near future, I'll be grabbing 2 more WD Caviars to run RAID 5 along with all the watercooling components (EK for as many of the components as I can find with the mobo being a limitation right now). A larger PS will be required if I go 12v on the pumps but I'm not sure where I'm going with that just yet.
Cooler Master 840
G.Skill Eco 4x2gb
3tb WD Caviar Green
Antec TPQ-850 PS
