I have problems with this mobo. I just reinstalled windows and I got this crash (I'll post both crash details and windows debugger output on the minidump file):
EVENT VIEWER:
Event Type: Error
Event Source: System Error
Event Category: (102)
Event ID: 1003
Date: 19/02/2005
Time: 19.00.57
User: N/A
Computer: EMANUELE-5FYNRY
Description:
Error code 10000050, parameter1 8811c906, parameter2 00000000, parameter3 8811c906, parameter4 00000000.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 53 79 73 74 65 6d 20 45 System E
0008: 72 72 6f 72 20 20 45 72 rror Er
0010: 72 6f 72 20 63 6f 64 65 ror code
0018: 20 31 30 30 30 30 30 35 1000005
0020: 30 20 20 50 61 72 61 6d 0 Param
0028: 65 74 65 72 73 20 38 38 eters 88
0030: 31 31 63 39 30 36 2c 20 11c906,
0038: 30 30 30 30 30 30 30
30 00000000
0040: 2c 20 38 38 31 31 63 39 , 8811c9
0048: 30 36 2c 20 30 30 30 30 06, 0000
0050: 30 30 30 30 0000
DEBUGGER:
Microsoft (R) Windows Debugger Version 6.4.0007.2
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini021905-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*DownstreamStore*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 2600.xpsp_sp2_rtm.040803-2158
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805644a0
Debug session time: Sat Feb 19 18:59:30.921 2005 (GMT+1)
System Uptime: 0 days 5:54:33.637
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
Unable to load image torususb.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for torususb.sys
*** ERROR: Module load completed but symbols could not be loaded for torususb.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 10000050, {8811c906, 0, 8811c906, 0}
Could not read faulting driver name
Probably caused by : torususb.sys ( torususb+5e31 )
Followup: MachineOwner
0: kd> .reload
My comp specs are:
CPU-Z version 1.26.
CPU(s)
Number of CPUs 2 (1 Physical)
CPU#1 APIC ID = 0
CPU Name Intel Pentium 4
Code Name Prescott
Specification Intel(R) Pentium(R) 4 CPU 3.20GHz
Family / Model / Stepping F 3 4
Extended Family / Model 0 0
Package mPGA-478
Core Stepping D0
Technology 0.09 ᄉ
Supported Instructions Sets MMX, SSE, SSE2, SSE3
CPU Clock Speed 3198.5 MHz
Clock multiplier x 16.0
Front Side Bus Frequency 199.9 MHz
Bus Speed 799.6 MHz
L1 Data Cache 16 KBytes, 8-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kᄉops, 8-way set associative
L2 Cache 1024 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 3198.5 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
CPU#2 APIC ID = 1
CPU Name Intel Pentium 4 (logical unit)
Mainboard and chipset
Motherboard manufacturer ASUSTeK Computer Inc.
Motherboard model P4P800-E, Rev 1.xx
BIOS vendor American Megatrends Inc.
BIOS revision 1004.001
BIOS release date 09/24/2004
Chipset Intel i865P/PE/G/i848P rev. A2
Southbridge Intel 82801EB (ICH5) rev. 2
Sensor chip Winbond W83627THF
FSB Select 800 MHz
Performance Mode disabled
Graphic Interface AGP
AGP Status enabled, rev. 3.0
AGP Data Transfert Rate 8x
AGP Max Rate 8x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 128 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 199.9 MHz
FSBRAM 1:1
CAS# Latency 3.0 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
# of memory modules 2
Module 0 Infineon DDR-SDRAM PC3200 - 512 MBytes
Module 1 Infineon DDR-SDRAM PC3200 - 512 MBytes
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
POV 5900xt
3 hd maxtor (40gb ide with the os + 1 120gb ide + 1 120gb sata)
I use the sound onboard and I have an USB ADSL modem (urmet adsl modem), which may be the cause (I only suppose).
What can I do ?
Should I install intel inf update ? (I dont use them, I use the windows drivers because I've read somewhere that they give a lot of problems).
What have I to do ?
Help tnx.
EVENT VIEWER:
Event Type: Error
Event ID: 1003
Date: 19/02/2005
Time: 19.00.57
User: N/A
Description:
Data:
30 00000000
DEBUGGER:
0: kd> .reload
My comp specs are:
CPU-Z version 1.26.
CPU(s)
CPU#1 APIC ID = 0
Code Name Prescott
Package mPGA-478
Core Stepping D0
Technology 0.09 ᄉ
Bus Speed 799.6 MHz
L2 Location On Chip
CPU#2 APIC ID = 1
FSB Select 800 MHz
AGP Max Rate 8x
Memory
DRAM Type DDR-SDRAM
FSBRAM 1:1
Software
POV 5900xt
What can I do ?
What have I to do ?
Help tnx.
