Hey guys, it's been a while since I've actually overclocked a cpu (a few years actually since I bought the E6400 & P5B Dlx in the sig from the classifieds with an idea of how far they could OC, thanks meionm). Anyway I decided to jump in on the Microcenter deal and buy a quad, but I can't get anything with 400fsb stable. Prime95.6 fails in a few mins at 400*8 and I can't even boot windows at 400*9 with the vcore as high as 1.6v (oh this is watercooled btw) and ram timings relaxed to 5-5-5-15 even though they run at 4-3-3-12 on 450fsb.
I have found that prime ran 389*9 ~ 3.5GHz for 16+ hrs on blend with 1.48v, peak temps in the mid 50s, usually in the high 40s. If this is as high as it can go I'd be totally satisfied with it, as I've been doing a lot of video encoding, but I just find it odd that I can get 450*9 on the e6400 but can't even do 400*8 on the quad.
Some of my bios settings:
Dram 800Mhz (1:1)
Pci-e Freq 101MHz
PCI Clock Sync Mode 33.33Mhz
Spread Spectrum Disabled
Memory Voltage 2.2V
VCore 1.48v taken up to 1.6v with no change in OC ability
FSB Termination Voltage 1.45v
NB VCore 1.55
SB VCore 1.6v
ICH Chipset Voltage 1.215v
So yea if you guys have any tips or advice, or tell me just to be happy with it
Thanks
Tipycol
Dram 800Mhz (1:1)
Pci-e Freq 101MHz
Memory Voltage 2.2V
NB VCore 1.55
SB VCore 1.6v
Thanks
Tipycol
