- Apr 6, 2008
Heey guys! I am new here so first of al hello to you all!
I just bought a new pc with the following specs:
MSI P6N nForce 650i SLI V2
Q6600 C2Q @ 3.0 GHz G0-stepping
Tuniq Tower 120 CPU cooler
TakeMS 2 GB DDR2 RAM PC6400
2 x MSI NX8800GT 512mb OC (660/1950)
450GB HD
The OC is done with:
FSB: 1333 MHz
Multplier: 9x
Memory clock: 667 MHz
CPU VCore: +0,0250v
vram: 1,9v
NB: 1,25v
SB: 1,5v
FSB VTT core: 16%
PCI-e bus: 100
Tried to OC above 3.15 GHz with 1400 FSB results in instability. I tried to up the CPU Vcore to 0,1000v, FSB VTT to 20%, Vram to 2,0v and NB to 1.4v but all with no results. System will run Prime95 for hours with no problem but keeps reboot randomly!
Also tried to up the memory clock above 700 and that resulted in no post!
I thought a G0 should be able to go way up 3.0, now i really hit a wall here. Is it because my motherboard can't handle it?
Hope you guys can help me out!
450GB HD
FSB: 1333 MHz
Multplier: 9x
CPU VCore: +0,0250v
vram: 1,9v
NB: 1,25v
SB: 1,5v
FSB VTT core: 16%
PCI-e bus: 100
