My friend recently decided to upgrade his comp a bit and picked up a HIS 3870 IceQ III. I tossed it in and it was laggy with XP, I checked GPU usage while running WoW and it only hit 16%. I didn't really feel like messing with that so he just went and got Vista Ultimate X64.
I got that all installed and after some searching found all the mobo drivers and installed them. Then I installed Cat 8.11's and restarted it, that literally put it at about 1 frame every 4 or 5 seconds. So I rebooted in safe mode and unistalled the Cat 8.11's and restarted it. And it worked fine again.
Did some research seems that card (and probably some others) are not supported by the default Bios, but they are by the newest one. So I downloaded Pc Chips bios and their recommended program AFUwin. And thats where it all ends, I try and fire up the BIOS with AFUwin and all I get is "Error loading driver". Nail in the coffin, anyone got any ideas on how to get AFUwin to work or the BIOS flashed (not I don't have a USB stick and no floppy).
