- Jul 11, 2004
- Palatine, IL
I'm thinking about putting a SCSI card in a small form factor PC I'm building which only has PCI slots. Most Ultra160 SCSI cards I've seen are PCI-X, though. My initial thoughts are that you cannot put PCI-X cards in PCI slots, however on several cards I've seen statements like this: "Uses the latest 64Bit / 66Mhz PCI interface (32-bit compatible)". Does that mean it's compatible with standard PCI slots or is it some sort of PCI-X backwards compatibility mode so it's compatible with the operating system? I know that the PCI-X bus has much more bandwidth than standard PCI which would degrade performance a bit.
Thanks,
Tim
Thanks,
Tim
