- Feb 24, 2005
- arizona (cave creek)
i hear yaRedstone said:The kid is finding out upgrading a mobo usually has a domino effect.
Dude. You're not helping.Vertical_Zer0 said:You might also want to take another look at SLI... just in case
actualy it shouldent mater that much a oc just needs a stable psu (little voltage variance) not more pinsbobmanfoo said:if you plan on OCin g that DFI board then i suggest getting a good 24pin PSU
as for the x800xl, don't expect a very good OC, i got 425/525 on an x800xl for a rig im building for someone, stock is 400/490
no, what im saying is some boards don't like to run on 20pin , heres straight from Andy of at OCZ forums, 'There is a known issue with a 20 pin PSU and this board. Using a 20 pin and setting the jumpers for 5v operation (4v max in BIOS) will not work.', so what good is getting that board and sticking a 20pin psu on it? stable cpu but no voltage for the ram, hince me suggesting him to get a 24pin if he plans to OC:sean478 said:actualy it shouldent mater that much a oc just needs a stable psu (little voltage variance) not more pins
o.... my bad dudebobmanfoo said:no, what im saying is some boards don't like to run on 20pin , heres straight from Andy of at OCZ forums, 'There is a known issue with a 20 pin PSU and this board. Using a 20 pin and setting the jumpers for 5v operation (4v max in BIOS) will not work.', so what good is getting that board and sticking a 20pin psu on it? stable cpu but no voltage for the ram, hince me suggesting him to get a 24pin if he plans to OC:
