Hi, after a few weeks of overclocking my pc its gone extremely slow, i dont know whats wrong with it. Its not unbearably slow but just not as fast as it should be if you know what i meen.
And for some reason the DRAM frequency options have dissapeared in my bios, i have just 133Mhz and 200Mhz options, i used to have all the other options, anyone know why they dissapeared?
I've ran prime 6-8hrs a day a few times and no errors there.
THIS IS SOME DATA FROM EVEREST APP:
CPU Type Intel Pentium 4
CPU Alias Northwood, A80532
CPU Stepping D1
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 2.80GHz
CPUID Revision 00000F29h
CPU Speed
CPU Clock 3464.77 MHz (original: [ EVALUATION ] MHz, overclock: 24%)
CPU Multiplier 21.0x
CPU FSB 164.99 MHz (original: 133 MHz, overclock: 24%)
Memory Bus 206.24 MHz
CPU Cache
L1 Trace Cache 12K Instructions
L1 Data Cache [ EVALUATION ]
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
Motherboard Properties
Motherboard Name Asus P4P800 SE (5 PCI, 1 AGP, 1 WiFi, 4 DDR DIMM, Audio, Gigabit LAN)
Chipset Properties
Motherboard Chipset Intel Springdale i865PE
Memory Timings 3-4-4-8 (CL-RCD-RP-RAS)
PAT Enabled
SPD Memory Modules
DIMM1: Kingston K 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-2-2-6 @ 133 MHz)
DIMM3: Kingston K [ EVALUATION ]
BIOS Properties
System BIOS Date 02/17/05
Video BIOS Date 03/11/14
DMI BIOS Version 080009
Graphics Processor Properties
Video Adapter Sapphire Radeon 9600 Atlantis
GPU Code Name RV350 (AGP 8x 1002 / 4150, Rev 00)
GPU Clock 385 MHz (original: [ EVALUATION ] MHz, overclock: 19%)
Memory Clock 226 MHz (original: 189 MHz, overclock: 20%)
Field Value
Sensor Properties
Sensor Type Winbond W83627THF (ISA 290h)
Motherboard Name Asus P4C800 / P4P800 / P4P8X
Chassis Intrusion Detected No
Temperatures
Motherboard 33 °C (91 °F)
CPU 36 °C (97 °F)
Maxtor 4R160L0 39 °C (102 °F)
Cooling Fans
CPU 4141 RPM
Chassis 2428 RPM
Voltage Values
CPU Core 1.60 V
+3.3 V 3.36 V
+5 V 5.05 V
+12 V 11.61 V
+5 V Standby 5.09 V
Is there something wrong there? ... am i using a setting that shouldnt be used? ... Please help, i think my pc is dieing, lol
Thanks
darren
CPU Stepping D1
CPU Speed
CPU Cache
Chipset Properties
PAT Enabled
SPD Memory Modules
BIOS Properties
Field Value
Sensor Properties
Temperatures
CPU 36 °C (97 °F)
Cooling Fans
CPU 4141 RPM
Chassis 2428 RPM
Voltage Values
CPU Core 1.60 V
+3.3 V 3.36 V
+5 V 5.05 V
+12 V 11.61 V
+5 V Standby 5.09 V
Thanks
darren
