It would be appropriate to back this up with proof. What tests have you done to verify this?
1.TRAS=TCL+TRCD+TRP 2.TRC=TRAS+TRTP 3.TWR=TRTP+TCL 4.TFAW=TRRD+TWTR+TCWL+TRTP (if you push the ram too hard super low tight high performance timings then you need some voltage DDR3 any kind of model can do 1.92V max or even more but make sure you go slowly and try 1.7V or 1.8V first or if it is too over the voltage limit it will fully kill your ram same goes with overvoltage in other computer parts) some timintgs like these require you to try slowly and guess the settings or go with original you need to make sure and try the TCL TRCD, TRP and some other timings Timings if they are not too low then the ram will boot up and run (too high or doesn't apply to ram rule will also make it fail to work) (normaly cl is lowest and then other timings should go into the calculation of the rule 1,2,3,4 if you watch these two websites they show you two rules in ram timing normaly if it dosen't fit into my 4 rules then ram might be unstable but will still run and full load
http://forum-en.msi.com/faq/article/ddr3-memory-timings-explained http://en.wikipedia.org/wiki/Memory_timings (FROM wiki Notes:
RAS : Row Address Strobe
CAS : Column Address Strobe
TWR : Write Recovery Time, the time that must elapse between the last write command to a row and precharging it. Generally, TRAS = TRCD + TWR.
TRC : Row Cycle Time. TRC = TRAS + TRP.) and from msi (keep the tRAS = CL + tRCD+tRP (+/-1))
This is based on your original ram timings is like if it is 11(TCL)-11(tRCD)-11(TRP)-28(TRAS) then you can apply my rule sometimes even the manufactures do not have perfect settings for their stock timings and if you apply my 4 ram rules it will make your ram faster load smoother and much more stable, lots of performance gain if you know and try to put the timings lower and overclock it but make sure you learn how to reset bios before you try to do anykind of overclocking or your computer will not boot up if settings are not perfect and then you might need to waste money on fixing it, also use an calculator it will help allot and save you time for calculating
Also when your in BIOS you will forget the rule unless you always overclock the RAM timings and memorized it, Even I have a piece of paper of my perfect ram timing rule before I overclock my ram timings
http://www.mediafire.com/download/emtw9srlcqcnzq9/memtest.exe Also heres the sofware to test your RAM but will only load 2GB max but you can load 8 of them if you have 8 cores and only 4 if you have only a 4 core cpu and only 2 mem test software can run if you only have 2 cores (Doesn't need to hit over 60% RAM usage to make sure it is stable if you load 4GB or more its already enough to test if it is stable) (make sure your other Overclock settings also work like FSB and CPU frequency and voltage or you will fail too boot up or test the ram properly because other settings like CPU will make your system crash)
