- Mar 24, 2010
Hi everybody!
Like the title says. e6850 @ 3.6ghz is my goal. (I know, should be a piece of cake, but the semi-noob here has problems!)
I'm an amateur, so I understand basic OC concepts, I just never had to tinker with voltage that much in the past and I feel like I'll need to for this.
I also never toyed with memory timings. Anyways...
What's in the modest box:
Intel e6850 (G0) @ 3.0ghz (idle 22c - Load 55c)
MSI P35 Neo mobo - PDF Manual link, BIOS settings at page 38: (http://download2.msi.com/files/downloads/mnu_exe/E7360v1.0.zip)
4GB DDR2 Ram: 2x 1GB Corsair and 2x 1GB Kingston (PC2-6400 - 5,5,5,18)
MSI N250GTS GPU
1x 250Gb SATA HDD(boot) + 1x 120Gb IDE HDD
550w Antec PSU
Air cooling (decent)
22" Samsung monitor
Win 7 - 64bit Ultimate
I'd like to have some settings to start with if any of you guys have a similar setup.
I've tried a few settings based on other e6850 users, but I've had crashes (had to repair OS, lol) or freezes so I'm looking for a little help to get to that 3.6 with as few crashes as possible
With stock settings I can run Small, Large FFT and Blend tests in Prime for 24hrs. No problemo.
OC attempts so far:
All mobo settings set to "auto", SpeedStep disabled Max 9x multiplier):
3.1, 3.2, 3.3, 3.4ghz OC's were successful. 3.5 is stablish, but behaves like 3.6 below.
3.6ghz @ 400 fsb - no vcore changes: BSOD or freezes at desktop.
3.6ghz @ 400 fsb - 1.3125v: stable for at least 5 min during Prime's Small and Large FFT stress tests, but FAILS after 5 seconds during Blend.
EDIT: I used a ratio of 1:1 for the memory so it stays below the stock 400mhz no matter how high I set the fsb. Well, It's at 400mhz when I reach 3.6ghz though.
I tried raising the Vcore, the FSB, NB and memory voltages bit by bit, without success, most of the time I couldn't even POST.
I also tried to disable Spread Spectrum.
Some suggested to disable CPU Halt CE1, CIA2 and TE2, but I can't find these in the BIOS, which is the latest (v.1.10) for this board.
Load temps never go above 60c.
That's where I am.
Thanks in advance for any pointers about ideal voltages and/or other things I might need to disable/enable for this to work.
MQ
MSI N250GTS GPU
550w Antec PSU
22" Samsung monitor
OC attempts so far:
That's where I am.
MQ
