- Apr 12, 2002
I am considering building a folding farm. Like any good farmer, I want to plan my plantings so I get the biggest harvest with the smallest investment/ best utilization of my farmland and my time. I have some ideas, but what I need is some feed back if my ideas are correct or not, and any practical advise (like, I’ve used that board and its great/crap/etc.)
First, I’d like to present my assumptions I used in developing this “crop rotation”. Later when commenting, please stay within my “property lines” (no farming on the neighbors plot!). I do not want to hear “run a dual megabucks” when I put a limit of most economical, unless you can present some reason why they are truly the most economical. Likewise, please feel free to tell me why my assumptions are wrong...don’t worry, I can take it. The reason I am posting this is I want to hear some other opinions.
Objective: Develop folding farm that is most economical on points per day/ per dollar basis. System should be painless (i.e. not needing constant attention. It should run trouble free.).
Assumptions:
1. Build all layers the same (server and folding layers). Server will also (I think) have a monitor, keyboard, mouse, and moderate HDD (20Gig). I am thinking build them all the same so once have the pattern, I can easily duplicate. Because of this, I will probably buy most parts from vendors, not e-bay, etc.
2. Moderate overclock to maximize economics. Not so far that the system become unstable. I’m thinking mobile Xp2500/2600 to say 2500 MHZ, or A64 to 2450 MHz. Therefore, I want a Motherboard/CPU that can take over clocking in stride. However, I don’t want “the best”, I want what will meet this criteria relatively painlessly (i.e. no trying to solder wires onto the MB, etc.) and no more. I am guessing I need a board that allows CPU voltage changes in the BIOS, along with BIOS FSB changes. I picked some motherboards below based on user feedback at Newegg. But I’d really like to hear from you all on this.
3. Operating system. Here I’d like some advise. I am the last one to support Bill G., but I hear all kinds of people on these forums struggling to keep headless Linux systems running. I am thinking buy some used hard drives (say 5-10 Gig units), slap on XP or 2000 and go. At some point, a $10 -$15 hard drive is worth it to cut out the struggle to keep a system without a hard drive running. In addition, I hear that headless units loose work during power failures or if the server goes down. Finally, I hear nasty rumors that Linux does not fold as fast as Windows. Feedback/advice welcome on this point.
4. Work Units – All this talk of QMD cores has me a little worried, but for now, I’d like to aim at “farming” big WU’s. That what I run most of the time on most of my current machines. So I am guessing 256 Meg of memory. I was thinking a single stick so if later the I need more I can added it.
5. I have an A64 and it is fast...320 ppd (on big WUs) typically running at 2450 MHz. However, I am assuming a Mobile XP 2500/2600 running at the same speed is only 10 to 15% slower (Anyone have some data either way on this?). If the A64 is only 15% faster, it really does not justify the added cost it seems.
6. A Motherboard with onboard video. I know you can by cheap video cards, but then I worry about them making the system unstable (my current T-bird machine has a funky video card that takes it down periodically). I know you may not need a video card all the time, but again I want painless (I have promised my wife that the farm will not be a huge time investment). I want to be able to hook a keyboard; mouse and monitor up to any layer and be able to work on it with out sticking in cards, etc.
7. Heat sinks. Yeah, it would be cool to have a row of the latest monster heatsinks on all the farm animals, but when you look at the numbers, it gets hard to justify a $45 heat sink when a $15 does just as good in some cases. So I want the cheapest heat sink which will cool enough to allow an overclock of say 2400-2500 MHz. This farm will be in my basement, so it will usually be at 60 to 70°F ambient. I’d really like to hear from anyone out there running a nice cheap HS doing this...yeah, its not sexy, but it is cost effective!
8. Motherboard FSB. I was thinking of buying a motherboard that can support 400 MHZ FSB out of the box. Then just step the standard FSB from 266 towards 400 and the CPU should be the limiting constraint.
9. Memory – same thing, get PC3200 memory, and 400 FSB should be no problem, so again the CPU should be the limiting factor. And since it really should not take over 400 FSB, even “cheap” PC3200 should do fine. Again, I’d like to hear your experiences here, good and bad.
10. Power supply. I know you can split them, but again this looks like it is also a source of hassle for people. I’d like the cheapest PS that will get the job done.
11. Ignore Power consumption. I know it is a factor, but I think hard facts as to what power systems actually consume (vs. specs, estimates, etc.) are few and far between. So my economics are strictly on purchase price.
To summarize, I want to build identical systems, operate headless, but with video output available and hard drives. Overclock a reasonable amount.
Here are some ideas ( just a starting point really)
CPU
Mobile XP 2500 http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-401&depa=1 $85
Mobile XP 2600 http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-436&depa=1 $95
Motherboard
Biostar M7VIZ http://www.newegg.com/app/ViewProductDesc.asp?description=13-138-231&depa=1 $44
ASRock K7S41 http://www.newegg.com/app/ViewProductDesc.asp?description=13-157-024&depa=1 $49
Asus A7V400-MX http://www.newegg.com/app/ViewProductDesc.asp?description=13-131-509&depa=1 $52
Abit VA-20 http://www.newegg.com/app/ViewProductDesc.asp?description=13-127-191&depa=1 $53
Memory
Roswell 256Mb http://www.newegg.com/app/ViewProductDesc.asp?description=20-223-024&depa=1 $22
Wintec 256 Mb http://www.newegg.com/app/ViewProductDesc.asp?description=20-161-614&depa=1 $23
Buffalo 256 Mb http://www.newegg.com/app/ViewProductDesc.asp?description=20-150-618&depa=1 $23
Heatsink
Dynatron BH-625 http://www.newegg.com/app/ViewProductDesc.asp?description=35-114-012&depa=0 $10.50 +$5 shipping
Masscool Falconrock http://www.newegg.com/app/ViewProductDesc.asp?description=35-150-023&depa=0 $11 +$5 shipping
Power Supply
Powermax 480W http://www.newegg.com/app/ViewProductDesc.asp?description=17-163-025&depa=0 $12+$7shipping
Roswell RV 300 http://www.newegg.com/app/ViewProductDesc.asp?description=17-182-001&depa=0 $14+$5 shipping
Basic layer – CPU $85
Motherboard $50
Memory $23
Heat Sink $16
Power supply $20
E-bay Hard drive $15
Price/layer =$193
Points per day =320*.85 = 272 (est. based on my current A64)
1.40ppd/$
I welcome your comments and ideas.
Assumptions:
CPU
Motherboard
Memory
Heatsink
Power Supply
Motherboard $50
Memory $23
Heat Sink $16
Power supply $20
Price/layer =$193
1.40ppd/$
