- Mar 27, 2005
- Fresno, CA
Well, this last weekend I had a very tragic volt-mod accident trying to mod a 7800GTX following this guide. I want to learn from my mistake because I really don't want to give up this part of the hobby. I know I can do it right if I just do it carefully and understand all the facts.
After doing lots of research on the net, I came across this example in our forums and also this example from XS forums. The second looks like this . . .
I basically followed this example and I included a female molex soldered to the voltage measuring points so that I could easily measure the vGPU and VDD voltages while the card is running. Since the people in the links above seemed to have success, I figured I would follow them and use Viper John's schematic as a reference. (I don't have a pictures of my card handy but it ended up looking similar.)
But when I plugged in my card and fired up the computer, I smelled a small hint of smoke. So I turned off the system right away and checked that the trim pots were turned for maximum resistance. Then I put the probe of my volt-meter into the female molex to check the vGPU. But when I turned it on again, a huge puff of smoke came out of my case. . . .
I’m trying to figure out what went wrong so I can avoid this in the future. But I'm having trouble figuring it out. I have a couple questions that I was hoping someone could answer to help clarify the problem. . . .
1. If I solder the ends of a trim pot to the card, then can I measure the resistance between the soldered points to know the resistance of the trim pot? . . . When I did the v-mod on the GPU, I first checked my 200 ohm trimmer was set to 200 ohms between the two prongs that I soldered (the two on the right). I even snipped off the one on the far left to avoid confusion or accidental contact. Then I soldered to the points shown in the guide. But when I put my meter to check the resistance between the two points I soldered, it was something other than 200 ohms (I don’t remember exactly but I think I remember something like 38 ohms which I know means major current. ) . . .. So the resistance between the soldered points should have been around 200 ohms, right? And if so, why would it be so much lower in my case?
2. Does it matter where on the card I use as a ground? . . . In the guide, Viper John used some capacitors as ground points because they were near the v-mod points. However, since I like to put my trimmer at the edge of the video card (not directly located at the v-mod point) I figured I would just use the ground located by the power connector (like in the picture above). Would this be a problem? (I didn’t think so because this person seems to have done it and worked just fine.) . . .
3. Does it matter if the volt-meter is grounded to the case when reading voltages? . . . At first I thought that was the reason the card smoked the second time I turned it on. . . . But thinking about it later, that didn’t really make sense. The volt-meter doesn’t act as a path to ground, right? It shouldn’t matter if the volt-meter is grounded on the card or on the case, true?
Thanks for any help, guys.
