- May 2, 2012
- Cheyenne, Wyoming, USA
All right everyone, so I've been on a few different forums and I'm still a bit bewildered about a few things when it comes to my plans for a new rig. It'll be my first time buying and assembling all of the components separately since I usually go OEM and just put a graphics card and PSU replacement. I have all of the components in a shopping cart on Newegg and I'm just kind of curious about whether or not they will give me the most bang for my buck. There is also the matter of Intel vs. AMD, I've heard Intel has the superior average and max FPS while gaming which is what I'll be doing. I don't have too many current intentions of CrossfireX or SLI if it comes down to it in the future though I may do just that. I mainly game and it is done casually, I want to be able to run smoothly on high-ultra settings. I'll be recycling a HDD and an Optical drive from my current CPU and placing them in this rig as well. Any suggestions you guys have as far as the rig goes would be greatly appreciated. I also have a question regarding the HD Radeon 6850 Vs. HD Radeon 6870. I know there has been a lot of debate on these forums already about it but I noticed the posts were quite old and the price gap has shrunken since they were made. Thanks for your time.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227
Mobo: Unsure
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
CPU: Unsure
Additional Cooling: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103022
Aftermarket CPU Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Thermal Paste: http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
If it would be possible to reduce the price on the CPU to get an i3 or something but not compromise the power, I would greatly appreciate the knowledge, I know there are a few i3's and another few AMD's that have lower price tags with similar bench marks but why are they cheaper? Simply because of the L2/L3 caches? Would those matter for someone who'll just be gaming, listening to music, browsing, and using voice chats?
Additiontal Information: I do not have a "Frys" or "Microcenter" anywhere close to me, I will be open to using newegg and Amazon, tigerdirect and I have a hateful past so I would like to avoid them if at all possible. I'm now looking to buy an Intel Board and processor, possibly an i5 2500k or i5 2400 ,not sure just yet. I do not plan on doing SLI anytime soon so a board that is cheaper and lacks SLI compatibility would be completely fine. I hope to have this build within a month or so and I know that products and pricing are subject to change greatly within that time frame. The resolution that I will probably be playing on primarily is 1366x768 but I would not mind upgrading to a 1080 resolution after upgrading my monitor and such. I appreciate all replies and feedback.
Mobo: Unsure
CPU: Unsure
