- Apr 17, 2012
- England
Hi.
I need some expert advice on my future build. Im looking to refresh my computer and I'm thinking of watercooling again. I used to own a thermaltake triple rad kit and really enjoyed it, but now watercooling has come a long way and the options are massive....
My main purpose of the kit is to provide stable temps when overclocking my i7920. I'm using an asus P6T SE board, 6 gb of Corsair dominator Ram, GTX560ti 448 GPU and a Thermaltake 750W PSU. I would also like the option to add my GPU to the loop in future and/or possibly add another GPU for SLi.
I've ordered an Arctic Cooling Accelero Twin Turbo Pro PWM Graphics Card Cooler for the time being as the stock fan is noisy and I may replace it with a waterblock in future, money permitting...
So My main choice is custom build or Factory build? I'm leaning more towards the custom option, as it gives me options to add my GPU waterblock in the future, however on reading reviews on the Corsair H100 kit, I'm thinking the custom build will be a lot more in cost. The Corsair kit is around £80 but even the bits I've shortlisted for a custom build is around £140. This figure is based on parts I added with little or no research, so I'm going to assume that after I get some recommendations, it will go up...
The Case I'm looking to buy is the Xigmatek Midgard 2 with window.
http://www.xigmatek.com/product.php?productid=155
My friend can't fault the midgard 1 he recently bought and because it has a dual rad slot on the top, I can either fit the corsair H100 or a different dual rad.
Other Parts that I have looked at include...
Watercool Heatkiller LC Rev3 CPU Waterblock
http://www.specialtech.co.uk/spshop/customer/product.php?productid=9047
Hardware Labs Black Ice® GT Stealth 240mm Dual Radiator : GTS240
http://www.specialtech.co.uk/spshop...lth-240mm-Dual-Radiator--GTS240-pid-3978.html
1/4" Thread Compression Fitting for 1/2" ID - 3/4" OD Tubing : Black Nickel
http://www.specialtech.co.uk/spshop/customer/product.php?productid=11206&cat=1220&page=
XSPC 200L/ph 5.25" Drive Bay Pump & Reservoir Combo : X20 200
http://www.specialtech.co.uk/spshop/customer/product.php?productid=13834
Fractal Design 120mm Silent Series Cooling Fan : FD-FAN-120
I'll have five of these, 2 drawing in, 2 on the rad and 1 back exhaust.
I'm liking the 1/2" Tubing look, so will probably go with that.
So as you can see I just plucked a lot of these parts off a retail site and I would love to hear your thoughts, either on the CorsairH100 or anything on my shopping list..
I'm going to assume a lot of you would recommend a different pump and radiator. I chose that one because of the space it will save me, but on hindsight, I could remove one of the 3.5"drive bays to accomodate the pump and reservoir.....
I was also toying with the idea of including a single radiator on the back. Not sure whether it would help, as it will be on the back connected to my back exhaust fan....
So please give me some input as what to think about with regards the above products........ Cost is a factor over performance increase, but I'm not wanting to skimp on anything if I can help it.
Thanks
Thanks
