torture test only.. what else should i try running?Scott9027 said:What test(s) did you run?
d94 said:well, i ran prime while i slept all nite (6hrs )
but when i stopped the test it didnt have anything calculated or w/e it does! no errors.. but no new lines either...
whats goin on here!?
any ideas why it wouldnt be working right?Prime95 said:24.13 is newer/better than 24.6.
d94 said:any ideas why it wouldnt be working right?
yo4444 said:Why then, wouldn't it work correctly if you are running only one instance of prime 95?
