- Dec 25, 2004
I don't think there is any other XPM wallet other than qt.
But I was told that I don't need the wallet to solo?
I Must have mis-read.
From the Readme!!!.txt file:
IMPORTANT NOTE ABOUT SOLO MINING
1. Use official Primecoin wallet with this miner.
2. Wallet setup: copy default "primecoin.conf" file from miner archive to "c:\Users\YourWindowsLoginName\AppData\Roaming\Primecoin" folder, then start wallet. Of course you can change
settings in "primecoin.conf" if you know what you are doing.
3. It is very important to have a lot of connections in Primecoin wallet, otherwise you will have many orphaned blocks.
So if you have only 8 active connections, you need to allow incoming connections, check related topics about it.
