- Aug 4, 2009
It's been a while guys, but here goes:
I recently purchased two additional sticks of ram on top of what I currently have.
Here is what I am using: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277. Here is what I purchased and tried installing today: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277. A bit slower, I understand.
My motherboard is this: GIGABYTE GA-MA790GPT-UD3H AM3 AMD 790GX http://www.newegg.com/Product/Product.aspx?Item=N82E16813128398 and I have more than enough power to it using this: Rosewill BRONZE Series RBR1000-M 1000W http://www.newegg.com/Product/Product.aspx?Item=N82E16817182188.
When I have either of the two sets of ram installed in the first two slots, the computer turns on fine. I've swapped them both out and it's ok, so I know that both sets of ram are working correctly. However, when I go to add anything more (6 or 8 gigs total) I cannot turn the computer on. The cpu fan doesn't spin, and the computer won't boot.
I've seen on the Newegg recommendations that others have had similar issues, but I haven't been able to find a solution. My bios is up to date, and I have fiddled with any settings. Can any of you offer any suggestions?
