- Nov 5, 2013
- Ottawa, ON
Okay so my extra video card (Radeon HD 7970) went faulty about 2 weeks ago and I sent it back to ASUS about a week and a half ago. I just got my replacement in the mail yesterday. They had sent me their newer model of the 7970 (the one with four DP ports and 2 DVI), I've never had nor heard of DP ports so my first question is this. Is it better than HDMI? It probably is if it's now the standard on newer video cards. How much better? If it isn't much better, should I bother buying a DP cable at all? I never bothered with DP on my gtx 780 TI because it has an optional HDMI port and I already have HDMI cables up the wazoo and I thought it was an HDMI port since they look exactly the same.
Second question/problem I ran the card temporarily in DVI mode to test it and the card will boot into windows and even let me game sometimes for 3-4 minutes and then the display will go black. My previous card crashed with rainbow colors and failed several stress tests and even ASUS agreed that it was destroyed and needed to be fixed so that's why they sent me a replacement. You can't get out of the black screen either I've left it on for 20 minutes and it doesn't fix itself.
I haven't stress tested this card but it seems to be a driver issue as every single time I uninstall the drivers I can use my computer for 45 minutes - an hour just fine with no problems. But I've tried about 4 separate drivers from ATI and the crappy ones windows update keeps trying to stick in they're all causing the black screen even when not gaming, so... I don't know. Could be the card, could be the drivers, but if ASUS just tested this card 4 days ago... I don't see how it can possibly be fried and if it was fried why can I use it just fine with no drivers? It doesn't make sense.
BTW PSU AND MOBO specs are:
Corsair TX850
ASUS Rampage IV Formula.
and other computer:
Corsair TX850
ASUS Maximus V Formula.
Corsair TX850
and other computer:
Corsair TX850
