Haha, I was so into the build I didn't even take any pics. All I can say is use two layers of blue painters' tape over the whole case until you are done if you are modding. Measure THRICE cut once! USE PILOT HOLES before larger bits... larger bits like to walk around on metal a lot!
I used a combination of a Dremel XRP (that I burnt up), a Dremel MultiPro, and a Jigsaw to cut all the non-circular holes. For the circular holes I used Lenox arbored hole saws(non-arbored are fine if you have a spare arbor from another purchase).
I used a 4.5" angle grinder to cut all the screws to length with a cutting wheel and a grinding wheel to smooth the end of the screws/bolts.
I used all flat-headed countersunk screws for the radgrills. I used two bosch high speed countersinking bits to counter sink the holes.
I bought a nice 29 piece set of hitachi drill bits(I normally use Dewalt but they were 25 bucks more expensive!) to drill all of the holes.
I used a 29 piece tap and die set to chase the buggered threads on the cut off screws and to tap out the holes on the bottom radiator's mounting holes so that they would accompany machine screws of the type that I had.
Since I had the painters' tape on the top and bottom of the case, I laid down the radgrill for the top and bottom radiators and measured to the sides of the case to make sure it was centered and borrowed a pair of hands to hold it while I traced the inner rim of the fan holes for the rad. I used the jigsaw to cut these holes roughly at first. Then, I went back and cleaned them up after mocking up the grill in the hole and seeing where it needed to be "edited".
Then, I measured for the holes for the fill ports and drilled them out with a 1inch hole saw.
Then I unscrewed all of the panels and accessories from the bottom of the case and mocked up how the radiator and HDD racks had to sit in there to be kosher with each other. I realized that I had to removed the front-most fan mount from the bay also. So, I removed it and remeasured. Then, with the mocked up rack in position, I used a "modified" sharpie (I narrowed the tip with a knife to fit in the screw holes) to mark the hole locations for the screws in the HDD rack and drilled out the holes.
Next, I marked where the 24 pin ATX connector needed to come through the middle divider. I used a carpenter's square to make sure that the TWO marks were lined up for the drill holes. I used a 1/2 inch drill bit for both holes and used a Dremel to connect the two holes so that I had a hole with nice, rounded edges. I did the same for the 8(4+4) pin power connector. However, I made a narrower hole with the same drill bit so that it would fit the smaller plug better.
Then, with the square, I drew on the middle divider the hole for the ventilation grill between the upper and lower chambers for flow from the bottom rad to the top chamber and cut it out with a jig saw and Dremel.
Next, I rough cut the grill with the jigsaw to cover the hole with room to spare on each side (roughly 3/4 of an inch). Then, I used the angle grinder to the the grill completely square by grinding until I was straight across each row of holes for all sides. Next, I painted the grill black and cleared it with Duplicolor automotive lacquer.
Then I measured off of the grill and cut the holes for the grommeted holes for the tubing to pass through. This was a 7/8 inch hole saw. Then, I mounted the grommets.
Next I decided where the holes needed to be in the motherboard tray so that I could pass the SATA cables and the USB header cable from the front of the case through the mobo tray and used the same "drill two holes and connect them" method.
Next came the FUN part... grommeting all of the holes so that they was no wire chaffing and for looks. I had to cut some of the grommeting to make the turns in the small holes behind the mobo. I didn't care about looks there so it wasn't pretty. But, it serves its purpose. Then, I grommeted the larger holes which were 50 times harder because it had to look good! The rectangular hole was easy except for getting the "mitered" corners to look good. Then I grommeted the grill.
Next came the sleeving. I sleeved everything but the SATA connectors. I thought that the 90 degree AC Ryan connectors looked great as is. So all I did for them was take off the stupid stickers that said SATA.... DUH! The two rear fans' (one on the side of the case on the "plus II" option mount and the rear fan) leads were cut, sleeved, soldered and heat-shrunk together. They run from the connection of the two fans at the edge of the rear fan to the fan controller over 16 gauge wire. This is of course sleeved with black 3 pin connectors. I also sleeved the power switch, power led, and hdd led wiring and ran it up to the motherboard through a hole in the tray that was already there. I took all of the wires apart and used a drill to twist them into a helix for easier sleeving and heat shrinking. I also sleeved all of the fans together on each radiator to one 16 gauge wire per radiator(one radiator worth of fans per channel on the fan controller). So, I have 7 Sanyo Denki San Aces, 3 on first channel(bottom rad), two on second channel(top rad), and two on third channel(case fans). It is a slightly positive pressure setup because of the lower speed/flow fan in the power supply.
Then I realized that I had too many Sata cables to run them through the factory cutout from the mobo and had to enlarge that and grommet it.
Then all that was left to do was to enlarge the holes in the outer skin of the case that I had already drilled to accommodate the larger machine screws and mount everything.
SORRY for the long write up. But, I figured that since I didn't have pics that I needed to be thorough.
