Hey guys:
Remember Project TT I did a few months back? The project never ends, more designing and fabricating is done since.
A new distribution block was planned to fix some hole location errors and changing to a screw based design instead of glue. A pump is also added to the block to improve flow and makes filling the loop a million times easier (I needed an external pump to fill the loop in my old design as there was no pump in the case).
The design:
Design sent to 3rd party CNC company and parts arrived:
A lot of sanding and polishing:
Since the distro plate is completely transparent, it will expose the messy rad mount and cables behind it, so my plan is to have a screen blocking up the majority of reservoir and water channel and have the rest covered up by white paint.
$15 19ich ebay screen:
The D5 pump mount is 3d printed by my trusty DLP 3d printer xD
Assembly time~
Cable manage = hiding cables in case. Hiden cables don't need to be managed coz you can't see it right?
Some liquid metal:
Delided 6700k, old but effective. 5ghz @1.7v
End result:
RGB surely yields more performance...
Haven't decided what to put on the screen behind the disto plate, any suggestions?
The design:
Assembly time~
Some liquid metal:
End result:
