- May 7, 2011
- Cook->Kent
While killing time and deciding how I was going to remove my heat sinks from my new G.Skill memory, I noticed that there seemed to be some gaps between the tape and the dies. After taking a closer look, quite a few were not even touching the tape at all, leaving a bit of a gap between the die and the casing.
This is really the only good shot as 1) looking into the sun isn't fun, 2) shooting without a macro lens is equally not fun, and 3) shooting handheld with a 200mm lens to try to mimic a macro, even with VR, is stupid. This particular circled die has a complete gap despite what the pic suggests. See points one, two, and three.
That said, this particular memory, F4-2400C15Q-32GRK, is the culprit. The other modules exhibit the same behavior and I would say the majority of the dies are not fully touching the tape across all four modules on-hand.
This is more of an FYI than anything as I'm popping these off in favor of some WC goodness anyway.
